Subject: Re: How to profile an EPICS application on Linux
Date: Mon, 10 Sep 2012 17:36:52 -0500
On 9/10/12 5:21 PM, Mark Rivers wrote:
> Here is the output of "time" when running it in a mode where "top" showed the application using about 95% of a single CPU (on a 16 core system).  This is with my calculations enabled.
> 23.547u 16.516s 0:52.39 76.4%   0+0k 0+24io 0pf+0w
> This is the output of time when the calculations are disabled and top shows about 80% CPU in my application.
> Disabling my calculations:
> 11.401u 8.008s 0:27.60 70.2%    0+0k 0+8io 0pf+0w
> So it spends a substantial amount of CPU time in both User Mode and Kernel Mode.
Hi, Mark.
OK, then I don't know what's going on.  Maybe gprof has problems
with threaded programs (??).
I'm really not answering your question now, but another idea: Is
your Linux system new enough that you have the perf subsystem
available?  You could try that instead:
$ perf record ../../bin/linux-x86/quadEMTestApp
$ perf report
Lewis
Re: How to profile an EPICS application on Linux Andrew Johnson
RE: How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux J. Lewis Muir
Prev: Re: camonitor bug for string as array of chars Andrew Johnson
Next: RE: camonitor bug for string as array of chars Mark Rivers
Prev: RE: How to profile an EPICS application on Linux Mark Rivers
Next: Re: How to profile an EPICS application on Linux Andrew Johnson
