You might consider a simple SNL program to manipulate an array and write it back ... Ned
From: "Hinko Kocevar" <[email protected]> To: "Steven M. Hartman" <[email protected]> Cc: "Tech Talk" <[email protected]> Sent: Thursday, September 13, 2012 9:01:09 AM Subject: Re: waveform changes using subArray
Dear Steven,
Thank you for the answer.
I see that if we want to have something like this functioning, we need to use several records with appropriate "connections" between them to get things done..
I was thinking about a second waveform that would act as "subArray". To bad that we can not set maximum number of elements for waveform (similar as for subArray) and be allowed to process only desired range.
Best regards, Hinko
On 09/13/2012 03:36 PM, Hartman, Steven M. wrote: > > On Sep 13, 2012, at 7:59 AM, Hinko Kocevar wrote: >> Can this be done in some other manner? The goal here would be to allow >> user to get/see/change/set only the part of waveform, that shes >> interested in. > > > > I did something similar a number of years ago to allow tuning of ramping waveforms. I used a subArray with a length of one element and an adjustable index into the array to inspect the elements, and an aoRecord to adjust that element for tuning. The aoRecord wrote to a genSub record which recalculated the waveform (recomputing the rest of the waveform based on the new input and smoothing around the changed element to avoid discontinuities). The genSub then populated the waveform output record which controlled the hardware. As I recall, I needed to do some tricks with DISV to control record processing (run mode versus tuning mode) and to sync the aoRecord with the waveform element when not in run mode. >
-- Hinko Kocevar Software development engineer Instrumentation Technologies d.d. Velika pot 22, SI-5250 Solkan - Slovenia T:+386 5 3352600, F:+386 5 3352601 E-mail: [email protected] http://www.i-tech.si
The information transmitted is intended solely for the addressee and may contain confidential and/or privileged information. Any review, retention, disclosure or other use by persons other than the intended recipient is prohibited. If you received this in error, please notify the sender and delete all copies.
- Re: waveform changes using subArray Hinko Kocevar
RE: access record info from asyn Mark Rivers
gpu integration into epics Sean Murray
<2012>
Re: waveform changes using subArray Tim Mooney
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
