Subject: CAC problem between RTEMS and vxWorks
To: EPICS tech-talk <[email protected]>
Date: Wed, 19 Sep 2012 12:18:31 -0400 (EDT)
All,
I'm having issues with a RTEMS client (3.14.11) accessing PVs from a vxWorks IOC (3.14.8.2).  When the RTEMS IOC is rebooted, sometimes it doesn't reconnect to the other IOC.  Even after connecting, I'm often getting timeouts on RTEMS and can't seem to maintain a solid connection between the two.
# timeouts on RTEMS client IOC
CAC: Unable to connect because "Connection timed out"
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "iocfel8.acc.jlab.org:5064"
    Source File: ../cac.cpp line 1145
    Current Time: Wed Sep 19 2012 11:52:27.183784942
After reboots, It stacks up new socket connections which isn't helping matters.
# casr on vxWorks IOC
TCP 129.57.214.101:1024(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1025(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1026(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1027(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1028(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1029(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1030(): User="rtems", V4.11, 4 Channels, Priority=0
TCP 129.57.214.101:1031(): User="rtems", V4.11, 4 Channels, Priority=0
Any help is greatly appreciated.
Wesley
RE: CAC problem between RTEMS and vxWorks Hill, Jeff
Prev: Doxygen and EPICS build system Ralph Lange
Next: Re: Doxygen and EPICS build system Andrew Johnson
Prev: Re: Doxygen and EPICS build system Ralph Lange
Next: RE: CAC problem between RTEMS and vxWorks Hill, Jeff
