Subject: RE: CAC problem between RTEMS and vxWorks
To: Wesley Moore <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 20 Sep 2012 23:42:39 +0000
Hi Wesley,
> TCP 129.57.214.101:1024(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1025(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1026(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1027(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1028(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1029(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1030(): User="rtems", V4.11, 4 Channels, Priority=0
> TCP 129.57.214.101:1031(): User="rtems", V4.11, 4 Channels, Priority=0
When abruptly rebooting the RTEMS system the TCP shutdown interactions
may not (probably don’t) occur, and when the new instance of the RTEMS
system starts up it begins a new CA circuit over TCP. What ephemeral
port is assigned to the new circuit (i.e. 1024 through 1031 above) is
is an implementation detail of the IP kernel. On some implementations
the same port gets reused, and typically TCP detects an attempt to start
a new circuit on the same port as a preexisting circuit, and the server
side hangs up. Otherwise, the server side waits the duration of a long
timeout, in case the client is just temporarily loosing connectivity,
before it hangs up. The order of the ephemeral port assignment depends
typically on what sockets have been created since rebooting, and so you
may get different port assignment orderings if there are many circuits
being created shortly after the IOC reboots.
> CAC: Unable to connect because "Connection timed out"
Make certain that full/half-duplex configuration match between the
switches and the IOCs that are involved. If the switch and the IOC don’t
match communication can proceed but it can be very slow and unreliable.
Sometimes you can see this by watching the beacons with casw. On vxWorks
you can sometimes see the Ethernet auto-negotiation parameters by typing
ifShow. In my experience, some of the vxWorks Ethernet drivers are
neglecting to turn on the continuous auto-negotiation option in the PHY
and so if the vxWorks system gets powered up before the switch it decides
to default the auto-negotiation parameters, and never tries to
auto-negotiate again. This can be a problem because switches are
typically set to continuously auto-negotiate.
Another possibility is too many collisions which can be sometimes seen
on vxWorks systems with ifShow, but this is an infrequently experienced
problem today, on modern switched Ethernet networks.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Wesley Moore
> Sent: Wednesday, September 19, 2012 10:19 AM
> To: EPICS tech-talk
> Subject: CAC problem between RTEMS and vxWorks
> All,
> I'm having issues with a RTEMS client (3.14.11) accessing PVs from a
> vxWorks IOC (3.14.8.2).  When the RTEMS IOC is rebooted, sometimes it
> doesn't reconnect to the other IOC.  Even after connecting, I'm often
> getting timeouts on RTEMS and can't seem to maintain a solid connection
> between the two.
> # timeouts on RTEMS client IOC
> CA.Client.Exception...............................................
>     Warning: "Virtual circuit disconnect"
>     Context: "iocfel8.acc.jlab.org:5064"
>     Source File: ../cac.cpp line 1145
>     Current Time: Wed Sep 19 2012 11:52:27.183784942
> After reboots, It stacks up new socket connections which isn't helping
> matters.
> # casr on vxWorks IOC
> Any help is greatly appreciated.
> Wesley
Re: CAC problem between RTEMS and vxWorks Dirk Zimoch
CAC problem between RTEMS and vxWorks Wesley Moore
Prev: Bug on autosave for the ULONG type array Kim, Kukhee
Next: Re: CAC problem between RTEMS and vxWorks Dirk Zimoch
Prev: CAC problem between RTEMS and vxWorks Wesley Moore
