Subject: Bug on autosave for the ULONG type array
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Sep 2012 11:18:22 -0700
Dear Tim and Everyone;
We are in SLAC, experiencing a trouble when restore ULONG type array PVs by the autosave.
The problem occurred when it tries restore larger than 2147483648 (0x80000000).
So, we drilled down to the dbrestore.c file and found it handles ULONG type as just LONG type.
So, we suggest to make patch as the followings for the dbrestore.c :
BEFORE
 554         case DBF_ULONG:
 555                 p_ulong[num_read++] = (unsigned long)atol(string);
 556                 break;
AFTER
 554         case DBF_ULONG:
 555                 p_ulong[num_read++] = (unsigned long)atoll(string);
 556                 break;
Please, give me your advice.
Thank you.
Best regards,
Kukhee
Kukhee Kim
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 64
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
Prev: EPICS Collaboration Meeting October 2012 Ilyou Kim
Next: RE: CAC problem between RTEMS and vxWorks Hill, Jeff
Prev: RE: CAC problem between RTEMS and vxWorks Hill, Jeff
Next: Problem with using strings to access enum indices on Windows Mark Rivers
