Subject: Re: CAC problem between RTEMS and vxWorks
To: EPICS tech-talk <[email protected]>
Date: Mon, 24 Sep 2012 11:56:46 +0200
On Friday, September 21, 2012 10:33:20 you wrote:
> I'm familiar with some of the issues that you guys pointed out, they can
> definitely bite you.  While double-checking your suggestions I found that
> one of the channels that was being monitored came from another vxWorks IOC
> (mistake on my part).  Surprise, surprise...it never has any disconnect
> issues.  Following that lead, I found that the problems seem to be centered
> around a dynamically assigned pv in one of my two sequencers.  When I
> hard-coded that pv assignment the problems went away.  This remains
> consistent.  What's confusing me a bit is that I use dynamic assignment in
> the working sequencer, I just don't do any reassignments.
> Ben - Any known issues with dynamic assignment/reassignment?  Perhaps
> specific to RTEMS?
Not until now.
Let me re-state the issue, so we are clear what's happening:
Scenario 1: you are using either static assign, or assign at runtime, but in
the latter case for each channel you assign at most once. This works as
expected.
Scenario 2: you re-assign at runtime. This fails (sometimes?), when some
participant is rebootet. I guess it is not the IOC hosting the client (i.e.
the SNL program) that gets re-bootet, but the server (where the PV resides),
because you are talking about failing re-connects. It is not completely clear
to me which side is VxWorks, which is RTEMS, and which causes problems when
rebootet, but my guess is that: the SNL program runs on a VxWorks IOC; the
servers are VxWorks and RTEMS; re-connect fails only if the server OS is RTEMS
and if the channel gets re-assigned at runtime.
Jeff:
Dynamic re-assign means in CA terms that the sequencer will issue a
ca_clear_channel (for some connected channel), immediately followed by a
ca_create_channel (to some other PV). Hmmm, what happens if there is a race
between the ca_clear_channel call and the disconnect event caused by the IOC
reboot? (Just think loud here.)
It should be possible to devise a simple test client that issues a long
sequence of such create/clear calls to check whether this is a CA problem.
Unfortunately my automatic test setup does not yet support RTEMS, so this will
take some time for me to do.
On Friday, September 21, 2012 11:37:03 Wesley Moore wrote:
> From: "J. Lewis Muir" <[email protected]>
> > There have been a number of bug fixes related to pvAssign.  You
> > can find these in the release notes (just search in the page for
> > "pvAssign"):
> >   http://www-csr.bessy.de/control/SoftDist/sequencer/Notes.html
> > What version of the sequencer are you using?
> I'm using 2-1-9.
In 2.1.9 all issues know to me have been resolved.
> Looking through all the release notes and also seq_if.c.
> I'm thinking of trying to de-assign the channel between uses.
As a short-term work-around, this seem sensible.
Cheers
Ben
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: CAC problem between RTEMS and vxWorks Wesley Moore
RE: CAC problem between RTEMS and vxWorks Hill, Jeff
Prev: Problem with using strings to access enum indices on Windows Mark Rivers
Next: Re: CAC problem between RTEMS and vxWorks Wesley Moore
Prev: Re: CAC problem between RTEMS and vxWorks Wesley Moore
