Subject: DHCP/BOOTP configuration for EPICS with RTEMS
To: [email protected]
Date: Mon, 24 Sep 2012 11:53:45 -0300
Hi all,
I'm struggling to setup a remote boot environment for my EPICS application on RTEMS. The log I get is:
My ip address is 10 .128 .11 .1
Hostname is sbc1
bootpc: DHCP server len is 6Ignoring BOOTP/DHCP option code 28
Boot file is /tftpboot/rtems
Command line is epics/sbc1/
Subnet mask is 255 .255 .0 .0
Server ip address is 10 .128 .11 .3
Gateway ip address is 0 .0 .0 .0
Log server ip address is 10 .128 .11 .3
bootpc_adjust_interface: add net route, error=114
***** Initializing NFS *****
Mount (null):/tftpboot/epics          <-- what was this "(null)" supposed to be?
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
mount failed: Invalid argument
***** Starting EPICS application *****
Can't set initial directory(/epics/sbc1/): No such file or directory
fatal error, exiting
I followed Norum's guide and got everything to compile. Then I created an example app.
makeBaseApp.pl -t example rtems
makeBaseApp.pl -i -t example rtems
After compiling, I set up the PC that will be acting as a server:
Created a /tftpboot directory
Put both generated binaries in it:
/tftpboot/rtems
/tftpboot/rtems.boot
My client is named "sbc1", so I put the st.cmd file, db and dbd directories in:
/tftpboot/epics/sbc1/
The client is a x86 computer running gPXE.
I tried passing different strings to the "command line" (option 129)
epics/sbc1 <-- this one gets me to an ioc prompt, but with no databases loaded
epics/
epics/sbc1/
/epics/sbc1/
10.128.11.3:/tftpboot/epics/sbc1/
etc..
I tried defining OMIT_NFS_SUPPORT and using only TFTP, but got something like
"Can't open /TFTP/BOOTP_HOST/epics/sbc1/st.cmd: No such file or directory"
I believe I'm missing some really simple configuration parameter...
My configuration files:
FILE /etc/default/tftpd-dha
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/tftpboot"
TFTP_ADDRESS="0.0.0.0:69"
FILE /etc/exports
/tftpboot *(rw,sync,no_root_squash)
FILE /etc/default/dchpd.conf
ddns-update-style none;
default-lease-time 600;
max-lease-time 7200;
# Enable network boot
allow booting;
allow bootp;
log-facility local7;
# Configure the network
option subnet-mask 255.255.0.0;
option broadcast-address 10.128.255.255;
option T128 code 128 = string;
option T129 code 129 = string;
subnet 10.128.0.0 netmask 255.255.0.0 {
   range 10.128.11.1 10.128.11.200;
group
   next-server 10.128.11.3;
   # DHCP send hostnames declared here
   use-host-decl-names on;
   option T128 e4:45:74:68:00:00; #EtherBoot
# Single Board Computer 1
   host sbc1
      option host-name "sbc1";
      hardware ethernet <MAC ADDRESS>; # ommited on purpose
      fixed-address 10.128.11.1;
      filename "/tftpboot/rtems";  # this works
      option T129 "epics/sbc1/"; # this doesn't
Thanks in advance,
Bruno Seiva Martins
Re: DHCP/BOOTP configuration for EPICS with RTEMS Eric Norum
Prev: Re: CAC problem between RTEMS and vxWorks Wesley Moore
Next: Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
Prev: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Eric Norum
