Subject: Re: Problem with using strings to access enum indices on Windows
Cc: "'Christian Schlepuetz'" <[email protected]>, "'[email protected]'" <[email protected]>, Peter Eng <[email protected]>, "'Sarvjit Shastri'" <[email protected]>, "'James Rezende Piton - LNLS'" <[email protected]>, "'Gerry Swislow'" <[email protected]>, "'Peter Kenesei'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Sep 2012 10:32:58 -0500
Hi Mark,
On 2012-09-23 Mark Rivers wrote:
> The problem is that the " %u %n" format string does not work on Windows.
> When I spoke to Andrew Johnson he said he thought this was because Windows
>  does not implement the %n format specifier.
> I have done some more investigation, and found that this is not the case.
>  The problem is the leading space before the %n specifier. On Windows when
>  sscanf hits the blank space in the format specifier, but does not find a
>  blank space in the input string, it stops parsing the input string. So it
>  never reaches the %n format specifier. The GNU run-time library behaves
>  differently, it processes %n even if there is no space in the input. I
>  think it is questionable as to which is the "correct" behavior.
Your further investigation reminded to check the Known Problems page; on
2012-01-26 I committed a change published a patch to R3.14.12.2 that removed
both spaces from the scanf() strings in dbConvert.c and dbFastLinkConv.c.  The
leading space in the format strings was never actually necessary, since the %u
skips leading spaces anyway.
Note that it is essential that we check for other characters that come after
the digits; for example consider setting the SCAN field of a record with the
string "5 seconds".  If we don't check that sscanf() consumes the whole string
then this could result in a 2-second scan period (there is no 's' on the end
of the official menu strings, so the choice string would not match).  That's
why the "%n" is an essential part of the format.  Using a "%u%n" format with
no space could break an existing application that relies on the numeric form
and happens to append a space or '\n' to its digits, but I thought this would
be fairly unlikely occur in reality.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Problem with using strings to access enum indices on Windows Mark Rivers
Prev: Re: Problem with using strings to access enum indices on Windows Eric Norum
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Prev: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Next: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
