1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Motor record -- URIP with soft limits
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Wed, 26 Sep 2012 14:41:37 +0000
One caveat.. Make sure the ERES field is set correctly before switching UEIP (normally it would be the same as MRES). Otherwise you can get into a mess because the motor record attempts to do a 'set position' each time UEIP is switched. So if ERES is wrong it would set an incorrect number of counts on the controller.
I think the logic there is something to do with wanting to keep RBV the same number if you switch UEIP.
Cheers,
Matt
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 26 September 2012 15:28
> To: J. Lewis Muir; Pearson, Matthew (DLSLtd,RAL,DIA)
> On the Newport XPS we switch UEIP back and forth, depending on whether
> we want the RBV field to hold the theoretical position or encoder
> position.  Sometimes one does not want to see the encoder jitter,
> sometimes one does.  This can be changed at run-time with medm, etc.
> Mark
> From: [email protected] [[email protected]] on
> behalf of J. Lewis Muir [[email protected]]
> Sent: Wednesday, September 26, 2012 9:25 AM
> To: [email protected]
> Subject: Re: Motor record -- URIP with soft limits
> On 9/26/12 5:21 AM, [email protected] wrote:
> > Hi,
> > The pmacAsynMotor driver doesn't know about the motor record UEIP or
> URIP fields, as these are just internal to the motor record. But the
> driver does set the 'encoder present' bit in the MSTA field, allowing
> the use of UEIP to switch between REP and RMP for the position
> readback.
> Hi, Matt.
> Thanks for the info.  I guess that means my motor records that
> use the pmacAsynMotor driver are configured incorrectly for what
> I want (i.e. having the RBV field reflect the position reported
> by the encoder). :-(  I'll try changing them to have UEIP set to
> Yes.
> Thanks!
> Lewis
Re: Motor record -- URIP with soft limits Ron Sluiter
Motor record -- URIP with soft limits Fong, Nia W.
Re: Motor record -- URIP with soft limits J. Lewis Muir
Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
RE: Motor record -- URIP with soft limits matthew.pearson
RE: Motor record -- URIP with soft limits Mark Rivers
Prev: RE: Motor record -- URIP with soft limits Mark Rivers
Next: Re: Motor record -- URIP with soft limits Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
