The same problem is in
<stream>/streamDevice/streamApp/Makefile.
I made a similar local modification,
+ifeq ($(BASE_3_14), YES)
clean:: myclean
+else
+clean: myclean
+endif
myclean:
$(RM) core* StreamDebug.log
I defer to Janet and Andrew on your "can we stay compatible"
question,
but I think the answer is No. We have to make changes like the
above to
maintain backwards compatibility.
Janet, Andrew,
I suggest we add a bunch of variables named ...CLEAN, that users can
set to add files that they wish to be cleaned.
Keep them separate for the different cleans (clean vs. realclean
etc.).
Then users have a simple way to get things removed, and we can
change the implementation of clean as we need it.
~Ralph
- Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
- Re: EPICS 3.15.0 incompatible make rules Dirk Zimoch
- EPICS 3.15.0 incompatible make rules Dirk Zimoch
- Re: EPICS 3.15.0 incompatible make rules Ron Sluiter
RE: Triggered autosave on exit Hu, Yong
<2012>
2025
<2012>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
