Subject: Re: EPICS 3.15.0 incompatible make rules
To: Ralph Lange <[email protected]>
Date: Mon, 08 Oct 2012 13:49:40 +0200
Ralph Lange wrote:
On Fri Oct 05 2012 17:51:24 GMT+0200 (CEST), Ron Sluiter <[email protected]> wrote:
The same problem is in <stream>/streamDevice/streamApp/Makefile.
I made a similar local modification,
+ifeq ($(BASE_3_14), YES)
 clean:: myclean
+else
+clean: myclean
+endif
myclean:
        $(RM) core* StreamDebug.log
I had already fixed this in version 2.6 like this:
ifeq ($(EPICS_REVISION),14)
clean:: myclean
else
clean: myclean
endif
(Even though it would falsely trigger on releases 1.14, 2.14, 4.14 and so on ...)
Dirk
EPICS 3.15.0 incompatible make rules Dirk Zimoch
Re: EPICS 3.15.0 incompatible make rules Ron Sluiter
Re: EPICS 3.15.0 incompatible make rules Ralph Lange
Prev: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Next: RE: Triggered autosave on exit Di Maio Franck
Next: First Use Of 3.14.12.2 - target builds try to produce code for host also Duane Voy
