Subject: First Use Of 3.14.12.2 - target builds try to produce code for host also
Cc: Duane Voy <[email protected]>
Date: Fri, 5 Oct 2012 20:49:54 +0000
I have built 3.14.12.2 on linux-x86 host for cross development to vxWorks-ppc604_long targets.
When I do 'gmake vxWorks-ppc604_long' the make system tries to produce code for linux-x86 as well, which is doomed to failure with code referencing VxWorks headers.
This behavior is different from any that I have seen in versions <= 3.14.10.
I have been reading documentation and googling and greping, and have tried everything I can think of to make CROSS_COMPILER_TARGET_ARCHS be -just- vxWorks-ppc604_long.  All with no luck.
I know this can't be a bug -- it must be something that I have done wrong.  Am I missing some (possibly new) configuration parameter when building Base -- or my target?
Below is a log of my actions in building EPICS Base - for reference.
This is my first request for help from tech-talk.
--> Duane C. Voy
install EPICS base distribution as root
  mkdir /usr/local/epics
  cd /usr/local/epics
  gunzip baseR3.14.12.2.tar.gz
  tar -xvf baseR3.14.12.2.tar
  mv base-3.14.12.2 base-3.14.12.2.vx61
  cd base-3.14.12.2.vx61
  export EPICS_HOST_ARCH=`startup/EpicsHostArch.pl`
edit: configure/CONFIG_SITE
  add CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc604_long
  comment out CROSS_COMPILER_HOST_ARCHS=
  change #COMPAT_TOOLS_313=YES to COMPAT_TOOLS_313=NO
no edit: configure/CONFIG_SITE_ENV
no edit: configure/RELEASE
no file: configure/os/CONFIG.linux-x86.linux-x86
no edit: configure/os/CONFIG.linux-x86.Common
no edit: configure/os/CONFIG.Common.vxWorks-ppc604_long
no file: configure/os/CONFIG.linux-x86.vxWorks-ppc604_long
no file: configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc604_long
edit: configure/os/CONFIG_SITE.linux-x86.Common
edit: configure/os/CONFIG_SITE.Common.vxWorksCommon
  comment #VXWORKS_VERSION = 5.5
  uncomment VXWORKS_VERSION = 6.1
  comment #WIND_BASE = /usr/local/vw/tornado22-$(ARCH_CLASS)
  add WIND_BASE = /fnal/ups/prd/vxworks/v6_1f2/Linux-2-mv5500
  uncomment WORKBENCH_VERSION = 2.3
build EPICS
  gmake clean uninstall
  gmake
Re: First Use Of 3.14.12.2 - target builds try to produce code for host also Ralph Lange
Prev: RE: Triggered autosave on exit Hu, Yong
Next: Re: Triggered autosave on exit Ralph Lange
Prev: Re: EPICS 3.15.0 incompatible make rules Dirk Zimoch
Next: Re: First Use Of 3.14.12.2 - target builds try to produce code for host also Ralph Lange
