Subject: Re: MEDM Wheel Switch
To: Anthony Andrews <[email protected]>
Cc: [email protected]
Date: Tue, 09 Oct 2012 10:09:55 +0900
(2012/10/09 9:47), Anthony Andrews wrote:
> Hi All,
> My name is Anthony (Tony) Andrews, and I'm a graduate student at Idaho
> State University.
> I would like to use a particular controller in MEDM called a "wheel
> switch".
> This controller has arrows for changing a number value up and down to
> three decimal places or so.
> However, the arrows and font size are currently too small to use
> effectively.
> Even when I change the size of the button, the size of the text and
> arrows doesn't change.
> Does anyone happen to know a way to make the arrows and font a bit larger?
Do you get the messages like:
 medmInit: Unable to load font widgetDM_60
   Trying default (fixed) instead
when you start medm?
Then the problem you have may be solved by:
1) define environment variables like widgetDM_60 etc. (please refer the
manual for detail)
or
2) use "-displayFont scalable" argument when you start medm.
Noboru Yamamoto
Acclerator contro group
J-PARC center/KEK & JAEA
JAPAN
> Thanks!
Noboru Yamamoto
Accelerator Control group
web: http://www-acc.kek.jp/EPICS_Gr/default.html
G+: https://plus.google.com/i/xW1BWwWsj3s:2rbmfOGOM4c
Re: MEDM Wheel Switch Jim Batch
MEDM Wheel Switch Anthony Andrews
Prev: MEDM Wheel Switch Anthony Andrews
Next: Re: MEDM Wheel Switch Jim Batch
