1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: MEDM Wheel Switch
To: [email protected]
Date: Tue, 09 Oct 2012 08:14:26 -0700
Take a look at this reference for installing fonts:
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/MEDM/MEDM.html#Fonts
Jim Batch
LIGO Hanford
Richland, WA
On 10/8/12 6:09 PM, Noboru Yamamoto wrote:
> Hi,
> (2012/10/09 9:47), Anthony Andrews wrote:
>> Hi All,
>> My name is Anthony (Tony) Andrews, and I'm a graduate student at Idaho
>> State University.
>> I would like to use a particular controller in MEDM called a "wheel
>> switch".
>> This controller has arrows for changing a number value up and down to
>> three decimal places or so.
>> However, the arrows and font size are currently too small to use
>> effectively.
>> Even when I change the size of the button, the size of the text and
>> arrows doesn't change.
>> Does anyone happen to know a way to make the arrows and font a bit larger?
> Do you get the messages like:
>  medmInit: Unable to load font widgetDM_60
>    Trying default (fixed) instead
> when you start medm?
> Then the problem you have may be solved by:
> 1) define environment variables like widgetDM_60 etc. (please refer the
> manual for detail)
> or
> 2) use "-displayFont scalable" argument when you start medm.
> Regards,
> Noboru Yamamoto
> Acclerator contro group
> J-PARC center/KEK & JAEA
> JAPAN
>> Thanks!
Re: MEDM Wheel Switch Anthony Andrews
Re: MEDM Wheel Switch Noboru Yamamoto
Prev: Re: MEDM Wheel Switch Noboru Yamamoto
Next: Re: MEDM Wheel Switch Anthony Andrews
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
