Subject: Re: MEDM Wheel Switch
To: Jim Batch <[email protected]>, Noboru Yamamoto <[email protected]>
Cc: [email protected]
Date: Tue, 9 Oct 2012 10:03:07 -0600
That worked perfectly!
Thank you very much!
On Tue, Oct 9, 2012 at 9:14 AM, Jim Batch <[email protected]> wrote:
Take a look at this reference for installing fonts:
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/MEDM/MEDM.html#Fonts
Jim Batch
LIGO Hanford
Richland, WA
On 10/8/12 6:09 PM, Noboru Yamamoto wrote:
> Hi,
> (2012/10/09 9:47), Anthony Andrews wrote:
>> Hi All,
>> My name is Anthony (Tony) Andrews, and I'm a graduate student at Idaho
>> State University.
>> I would like to use a particular controller in MEDM called a "wheel
>> switch".
>> This controller has arrows for changing a number value up and down to
>> three decimal places or so.
>> However, the arrows and font size are currently too small to use
>> effectively.
>> Even when I change the size of the button, the size of the text and
>> arrows doesn't change.
>> Does anyone happen to know a way to make the arrows and font a bit larger?
> Do you get the messages like:
>  medmInit: Unable to load font widgetDM_60
>    Trying default (fixed) instead
> when you start medm?
> Then the problem you have may be solved by:
> 1) define environment variables like widgetDM_60 etc. (please refer the
> manual for detail)
> or
> 2) use "-displayFont scalable" argument when you start medm.
> Regards,
> Noboru Yamamoto
> Acclerator contro group
> J-PARC center/KEK & JAEA
> JAPAN
>> Thanks!
MEDM Wheel Switch Anthony Andrews
Re: MEDM Wheel Switch Noboru Yamamoto
Re: MEDM Wheel Switch Jim Batch
Prev: Re: MEDM Wheel Switch Jim Batch
Next: RE: areaDetector R1-8 released Chen, Xihui
Next: Job Openings at SNS/ORNL Hartman, Steven M.
