Subject: Re: strange EPICS glitch
Cc: "[email protected] talk" <[email protected]>
Date: Mon, 12 Nov 2012 12:57:56 -0800
Would this fix things?
--- devAsynOctet.c 2012-06-25 15:20:07.000000000 -0700
+++ devAsynOctet.c.proposed 2012-11-12 12:55:29.000000000 -0800
@@ -657,17 +657,21 @@
 static void callbackWfRead(asynUser *pasynUser)
     devPvt         *pdevPvt = (devPvt *)pasynUser->userPvt;
     waveformRecord *pwf = (waveformRecord *)pdevPvt->precord;
     size_t         nBytesRead;
     asynStatus     status;
     status = readIt(pasynUser,pwf->bptr,pwf->nelm,&nBytesRead);
-    if(status==asynSuccess) pwf->nord = nBytesRead;
+    if(status==asynSuccess) {
+        pwf->nord = nBytesRead;
+        if (pwf->nelm > pwf->nord)
+            *((char *)pwf->bptr + pwf->nord) = '\0';
     finish((dbCommon *)pwf);
 static long initWfWrite(waveformRecord *pwf)
     asynStatus status;
     devPvt     *pdevPvt;
On Nov 12, 2012, at 12:43 PM, Mark Rivers <[email protected]> wrote:
Hi Andrew,
I will change asynPortDriver so that the setStringParam() method adds a Nil and passes that length to device support on readOctet or asynOctet callbacks.  That will fix the problem with areaDetector, which is probably the main driver class using long strings for path names, etc.
This cannot be moved up to asynWfOctetRead/asynWfOctetWrite device support in asyn/devEpics/devAsynOctet.c, because the asynOctet support for the waveform record needs to be able to handle binary data.  However, we could add a new device support in there that was specifically for strings, e.g. asynWfOctetStringRead/asynWfOctetStringWrite.  These could enforce the Nils in both directions.
Eric Norum
[email protected]
RE: strange EPICS glitch Mark Rivers
Prev: streamDevice 32-bit hex value read problem Martin L. Smith
Next: RE: strange EPICS glitch Mark Rivers
Prev: Re: streamDevice 32-bit hex value read problem Martin L. Smith
