Subject: streamDevice 32-bit hex value read problem
To: [email protected]
Date: Mon, 12 Nov 2012 14:21:00 -0600
I'm trying to read a 32-bit hex value like ffffffff ffffffff using
EPICS R3.14.12.2, streamDevice 2-5, and asyn 4-19 on 64-bit Linux OS.
When I read these values using the following protocol:
get_ilock {
	out "din";
	in "%(\$1FirstInterlockWord.VAL)8R ",
	   "%(\$1SecondInterlockWord.VAL)0R";
	ExtraInput = Ignore;
Both records are longin records and no matter if I use the 8R or 0R I
always get the same result:
 ID06ds:FirstInterlockWord      11/12/12 14:03:02.743812335 -2147483648
 ID06ds:SecondInterlockWord     11/12/12 14:03:02.743823268 -2147483648
Turns out that this is hex value 80000000
If I use a strngin record I can see that I'm getting the expected data.
Is this the largest value that I can read using streamDevice or is there
some other way that I should try to read these values?
Marty
RE: streamDevice 32-bit hex value read problem Allison, Stephanie
Re: streamDevice 32-bit hex value read problem Dirk Zimoch
Prev: RE: procServ softIOC server - V2.6.0 released Mark Rivers
Next: Re: strange EPICS glitch Eric Norum
Prev: Senior Software Engineer needed at MSU's FRIB careers
Next: RE: streamDevice 32-bit hex value read problem Allison, Stephanie
