Subject: RE: streamDevice 32-bit hex value read problem
To: "'Martin L. Smith'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 12 Nov 2012 15:08:40 -0800
Hi Marty -
So you are reading 2 unsigned 32 bit integers into 2 longin records (and longin's are signed 32 bit integers even on 64bit machines).
Could you instead read into 2 ai records?  Or into A and B fields of an aSub record where FTA and FTB are "ULONG"?
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Martin L. Smith
> Sent: Monday, November 12, 2012 12:21 PM
> To: [email protected]
> Subject: streamDevice 32-bit hex value read problem
> I'm trying to read a 32-bit hex value like ffffffff ffffffff using
> EPICS R3.14.12.2, streamDevice 2-5, and asyn 4-19 on 64-bit Linux OS.
> When I read these values using the following protocol:
> get_ilock {
> 	out "din";
> 	in "%(\$1FirstInterlockWord.VAL)8R ",
> 	   "%(\$1SecondInterlockWord.VAL)0R";
> 	ExtraInput = Ignore;
> Both records are longin records and no matter if I use the 8R or 0R I
> always get the same result:
>   ID06ds:FirstInterlockWord      11/12/12 14:03:02.743812335 -2147483648
>   ID06ds:SecondInterlockWord     11/12/12 14:03:02.743823268 -2147483648
> Turns out that this is hex value 80000000
> If I use a strngin record I can see that I'm getting the expected data.
> Is this the largest value that I can read using streamDevice or is there
> some other way that I should try to read these values?
> Thanks,
> Marty
streamDevice 32-bit hex value read problem Martin L. Smith
Prev: Re: strange EPICS glitch Andrew Johnson
Next: question of Hytec 8516 added in synApps-5.3 李芳
Prev: streamDevice 32-bit hex value read problem Martin L. Smith
Next: Re: streamDevice 32-bit hex value read problem Dirk Zimoch
