Subject: streamDevice Exception Handler Question
To: [email protected]
Date: Thu, 15 Nov 2012 08:33:30 -0600
When using steamDevice exception handlers and in particular the
replytimeout and readtimeout handlers, what would one normally
do in these handlers?
For a mismatch I simply get whatever the received data was and put
that in a string record for display so that I know that something
went wrong ... since the error messages are now suppressed from this
error.
Is it possible to set a PV to a value without using an "in" command?
Or would I simply look at the STAT field of the record using the protocol
to know that something happened in the case of a timeout error?
Marty
Re: streamDevice Exception Handler Question Dirk Zimoch
Prev: StreamDevice and sCalcoutRecord.h Pavel Maslov
Next: Re: StreamDevice and sCalcoutRecord.h Tim Mooney
Prev: Re: StreamDevice and sCalcoutRecord.h Pavel Maslov
Next: Re: streamDevice Exception Handler Question Dirk Zimoch
