Subject: Re: StreamDevice and sCalcoutRecord.h
To: Dirk Zimoch <[email protected]>
Date: Thu, 15 Nov 2012 17:40:15 +0100
Ok. The problem was resolved by commenting out some CALC and SYNAPPS lines in the makefiles. Although, it's strange that I didn't have such problems on windows x86 and linux machines (CentOS), but on Ubuntu 64bit it resulted in one error or another. Even if I didn't specify CALC and SYNAPPS in the RELEASE file.
Thanks anyway,
P.
On Thu, Nov 15, 2012 at 4:57 PM, Dirk Zimoch <[email protected]> wrote:
On 15.11.2012 16:48, Dirk Zimoch wrote:
On 15.11.2012 11:12, Pavel Maslov wrote:
When I try to compile StreamDevice (ASYN 4-16, base 3.14.12,
StreamDevice 2-4, 2-5), I get the following error. What's wrong? Any
ideas?
//usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -Wall -m64 -g -fPIC -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
-I/home/operator/applications/epics/modules/asyn/include
-I/home/operator/applications/epics/base/include/os/Linux
../devscalcoutStream.c/
/../devscalcoutStream.c:21:28: warning: sCalcoutRecord.h: No such file
or directory/
Hello Pavel,
sCalcout is an optional record from SynApps. If you don't have SynApps
installed, you can skip the whole srcSynApps subtree of StreamDevice.
I thought that I had a mechanism in the srcSynApps/Makefile that
compiles the stuff only if SynApps is installed, but maybe there is
something wrong there. I will check this.
Dirk
I have this in the toplevel Makefile:
  include $(TOP)/configure/CONFIG
  ifneq ($(words $(CALC) $(SYNAPPS)), 0)
    # with synApps calc module (contains scalcout)
    DIRS += srcSynApps
    srcSynApps_DEPEND_DIRS  = src
    streamApp_DEPEND_DIRS  += srcSynApps
  endif
So if you have defined either CALC or SYNAPPS in your RELEASE file, then StreamDevice assumes that this points to the place where to find sCalcoutRecord.h. Otherwise, the whole srcSynApps tree will be skipped.
Is is possible that you have installed but not yet build SynApps (or its calc module)?
Dirk
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
StreamDevice and sCalcoutRecord.h Pavel Maslov
Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
Prev: Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
Next: Re: Long string support in CA clients and device support Andrew Johnson
Next: streamDevice Exception Handler Question Martin L. Smith
