1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Record processing: periodic vs. push vs. pull
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Dec 2012 10:26:10 +1100
Hi Jon,
It's an interesting question, and I'm sure the 'best' solution (if there is one!) will depend on your application.
When I am doing serial comms e.g. StreamDevice, I try to keep the number of periodically scanned records to a minimum.  For example, I might use a fanout record with SCAN .5 second linking to PASSIVE records which actually do the work.  This means that if I want to change the scan rate I only need to change a single record, or I can turn off comms altogether by disabling just this one record.
I've personally never used the PHAS field, and someone can correct me but I think this is not usually recommended?
As for 'push' vs 'pull', I'm never quite sure which to use either.  Unless I really need event driven processing (e.g. to catch every update from a device), I usually tend towards the pull approach.  I find this is best for flexibility for adding functionality later on, otherwise I end up with long chains of FLNKed records which I try to avoid as it creates dependencies between tasks which are not necessarily related.
Just my thoughts on the subject anyway!
Cheers,
Emma
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of [email protected]
> Sent: Friday, 21 December 2012 5:30 AM
> To: [email protected]
> Subject: Record processing: periodic vs. push vs. pull
> One of the EPICS Getting Started slide decks (ref below) discusses
> alternatives for record processing in a chain of three records where
> data flows: ai VAL -> INPA calc VAL -> DOL ao.  The alternatives are:
> 1. Periodic: all three records have SCAN .1 second, with advancing
> phase:
>     ai PHAS 0 -> calc PHAS 1 -> ao PHAS 2
> 2. Push: input ai record is periodic, others are passive, with forward
> links:
>    ai FLNK -> calc FLNK -> ao
> 3. Pull: output ao record is periodic, others are passive, with input
> links
>     INP and DOL with PP attribute (here arrows show control not data
> flow):
>     ai <- INPA PP calc <- DOL PP ao
> I wonder how to choose among these.  I can think of these pros and
> cons:
> 1. Periodic
> Pro: i. Record definitions do not depend on control flow, no INP PP or
> FLNK
>      ii. No control flow subtleties, records always processed on fixed
> schedule
> Con: i. Processing occurs on fixed schedule, regardless of events or
> demand
>      ii. Might have to tweak control flow after all, with PHAS
> 2. Push
> Pro: i. Processing can be driven by events, when data appears or
> changes
>          (in input ai, replace SCAN .1 second with I/O Intr or ...)
> Con: i. Input record definitions depend on downstream data processing
>          (must anticipate where data will be consumed to define FLNK)
> 3. Pull
> Pro: i. Processing can be driven by demand
>          (in output ao, replace SCAN .1 second with input from FLNK or
>      ii. Input record definitions do not depend on downstream
> processing
> Con: i. Control flow may be difficult to analyze or understand, for
> example
>          INP PP gets old value instead of waiting for asynchronous
> completion
>          INP PP flag ignored in CA links (to other IOCs), behaves like
> NPP
> Have I overlooked any important pros or cons?  Is there one alternative
> that is more common, or one that is recommended (or discouraged)?
> Jon Jacky
> PS - The three alteratives appear in slide 29, "Processing chains", in:
> What is an EPICS database?  Andrew Johnson  2004
> http://www.aps.anl.gov/bcda/epicsgettingstarted/iocs/Database1&2_1up.pd
> f
Record processing: periodic vs. push vs. pull jon
Prev: CSS XY Graph Pause John Dobbins
Next: Re: CSS XY Graph Pause Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Record processing: periodic vs. push vs. pull jon
Next: Re: Record processing: periodic vs. push vs. pull Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
