Subject: Re: CSS XY Graph Pause
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 21 Dec 2012 11:41:59 +0400
Hi John,
Is there an option "Plot n points and stop" in CSS Boy?
Another solution would be to implement a record that will use the SDIS field of your waveform record to switch it back and forth (1 to 0). So you will click the button and it stops updating data from the scope. Click again, and - presto! - new data has arrived.
On Fri, Dec 21, 2012 at 2:28 AM, John Dobbins <[email protected]> wrote:
Hello All,
I am using a CSS XY graph to display a waveform. The graph actually displays the last n values on the waveform presenting an oscilloscope like trace. I would like to be able to pause the display. Can someone recommend a way of doing this?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: CSS XY Graph Pause Peter Milne
CSS XY Graph Pause John Dobbins
Prev: RE: Record processing: periodic vs. push vs. pull Emma Shepherd
Next: Re: CSS XY Graph Pause Peter Milne
Prev: CSS XY Graph Pause John Dobbins
