1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Alter Perl hashbang in capr.pl
To: [email protected]
Date: Fri, 18 Jan 2013 17:19:18 -0600
On 2013-01-18 Ralph Lange wrote:
> A more elegant portable solution is replacing the hashbang with
>     eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
>         if 0;
> That will find perl in the PATH.
It seems the recommended way to handle this has changed a bit over the years.
The current trend for both Perl and Python seems to be to use /usr/bin/env,
which finds perl in the path without being quite so verbose:
#!/usr/bin/env perl
All modern Unix-type systems understand the #! line and have the env program
in /usr/bin — even Solaris and Cygwin.  The magical parts in the above eval
were needed to get around various specific shells that might be executing the
script, but I don't believe anyone will be trying to run EPICS on the exotic
ones nowadays (and they're not needed if the script has a #! line).
Windows does not understand either the #! line or any of the above magic, so
the EPICS build system always explicitly includes $(PERL) in the command line
and I think manually running perl scripts will always require that too.
I propose to change the preamble of all the Perl scripts in base-3.14 to the
above; any objections?  There's a patch file of the necessary changes at
  http://www.aps.anl.gov/epics/base/R3-14/12-docs/envPerl.patch
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: Alter Perl hashbang in capr.pl J. Lewis Muir
Alter Perl hashbang in capr.pl Shankar, Murali
Re: Alter Perl hashbang in capr.pl Ralph Lange
Prev: Re: Alter Perl hashbang in capr.pl J. Lewis Muir
Next: femto and std Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Alter Perl hashbang in capr.pl J. Lewis Muir
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
