1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: BOY number representation & display scaling
To: [email protected]
Date: Fri, 25 Jan 2013 18:00:08 -0500
Exploring BOY-land from medm.
1) Using BOY, I want large numbers to be displayed with no comma.
e.g.  145,123 I want to display as 145123
Widget type text update, format type decimal. Tried format string and
that showed gibberish. Also tried a few others widget types to no
avail. I tried several LC_NUMERIC environment settings before css
launch, no help there.
Any ideas?
2) With medm, when I resized a display's window the entire display
scaled.  With BOY this is not the behavior - you just shrink the
visible portion of the display.  To shrink/enlarge/scale the entire
display takes several steps and the F8 key.  Is there a trick or
setting to rescale the entire display - widgets, text, objects?  Does
a WebOPI display behave any differently in this regard?
just some comments on my experience:
Had success with SNS Basic_EPICS version.
I was very impressed with how quickly I was able to adl2boy our 400
medm displays.  Most needed a tweak (compound visibility rule) and
some wouldn't convert (shell script launcher?)  but basically they all
worked. adl2boy worked on my 32-bit RHEL5 Basic_EPICS but not on my
64-bit RHEL_5.
I like the tabbing feature when additional displays are brought up,
but I also like to arrange many displays across numerous operator
screens - often shrinking the displays to get more on there all
visible at once.  I added an action button to each display to 'detach'
;  that gets me my displays on independent windows.  I tried to drag
the display's tab out of the window but this didn't work.  I also
thought a right-click option to 'detach' would also be useful ...I
know  I know, if I want that feature then code it up  :).  But my
window resize/rescale issue remains.  The operators are used to this
feature.
-ps
RE: BOY number representation & display scaling Kasemir, Kay
Re: BOY number representation & display scaling Paul Sichta
RE: BOY number representation & display scaling Chen, Xihui
Prev: copying archived data from 32-bit to 64-bit machine Pierrick Hanlet
Next: RE: BOY number representation & display scaling Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: copying archived data from 32-bit to 64-bit machine Bruce Hill
