1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: BOY number representation & display scaling
To: [email protected]
Date: Fri, 25 Jan 2013 22:01:13 -0500
To suppress the comma for 1,000's:
In java.text.NumberFormat;
I need to specify  setgroupingused(false) for that value.  So, this I
cannot change in the Basic_EPICS package I downloaded from SNS.
-ps
On Fri, Jan 25, 2013 at 6:00 PM, Paul Sichta <[email protected]> wrote:
> Exploring BOY-land from medm.
> 1) Using BOY, I want large numbers to be displayed with no comma.
> e.g.  145,123 I want to display as 145123
> Widget type text update, format type decimal. Tried format string and
> that showed gibberish. Also tried a few others widget types to no
> avail. I tried several LC_NUMERIC environment settings before css
> launch, no help there.
> Any ideas?
> 2) With medm, when I resized a display's window the entire display
> scaled.  With BOY this is not the behavior - you just shrink the
> visible portion of the display.  To shrink/enlarge/scale the entire
> display takes several steps and the F8 key.  Is there a trick or
> setting to rescale the entire display - widgets, text, objects?  Does
> a WebOPI display behave any differently in this regard?
> just some comments on my experience:
> Had success with SNS Basic_EPICS version.
> I was very impressed with how quickly I was able to adl2boy our 400
> medm displays.  Most needed a tweak (compound visibility rule) and
> some wouldn't convert (shell script launcher?)  but basically they all
> worked. adl2boy worked on my 32-bit RHEL5 Basic_EPICS but not on my
> 64-bit RHEL_5.
> I like the tabbing feature when additional displays are brought up,
> but I also like to arrange many displays across numerous operator
> screens - often shrinking the displays to get more on there all
> visible at once.  I added an action button to each display to 'detach'
> ;  that gets me my displays on independent windows.  I tried to drag
> the display's tab out of the window but this didn't work.  I also
> thought a right-click option to 'detach' would also be useful ...I
> know  I know, if I want that feature then code it up  :).  But my
> window resize/rescale issue remains.  The operators are used to this
> feature.
> -ps
BOY number representation & display scaling Paul Sichta
Prev: Re: copying archived data from 32-bit to 64-bit machine James F Ross
Next: Re: copying archived data from 32-bit to 64-bit machine Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: BOY number representation & display scaling Kasemir, Kay
Next: RE: BOY number representation & display scaling Chen, Xihui
