1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: memory and vxWorks based IOCs
To: Paul Sichta <[email protected]>
Date: Mon, 28 Jan 2013 12:45:32 -0500
Cool, I'll look into both options.  Thanks a bunch!
James
On Mon, Jan 28, 2013 at 12:41 PM, Paul Sichta <[email protected]> wrote:
The predecessor to devIocStats was vxStats.  This goes back prior to
3.13.10.  Here's an old tech-talk thread that might get you going.  I
used it for 68060 IOC's.
http://www.aps.anl.gov/epics/tech-talk/2006/msg00055.php
My vxworks machine would complain about "ENOBUFS" and refuse to
accepts additional client connections. I could go months between
problems.
Another idea would be to put a CA gateway between your old IOC and the
network (of clients).  This way, the gateway handles the multiple
clients comm.
-ps
On Mon, Jan 28, 2013 at 12:23 PM, James F Ross
> I don't believe that I am running devIocStats.  It is running a very old
> version of epics: 3.13.10.  Do you happen to know if this is compatible with
> devIocStats?  If so, and I install it, would it require changes to the
> source code or just to the db files to include a memory PV?
> Thanks!
> James
> On Mon, Jan 28, 2013 at 11:34 AM, Tim Mooney <[email protected]> wrote:
>> Hi James,
>> Are you running devIocStats?
>> http://www.slac.stanford.edu/grp/cd/soft/epics/site/devIocStats/
>> If so, memory is available as a PV whose value you could record in any
>> number of ways.
>> Tim
>> ________________________________
>> From: "James F Ross" <[email protected]>
>> To: "EPICS Tech Talk" <[email protected]>
>> Sent: Monday, January 28, 2013 10:18:52 AM
>> Subject: memory and vxWorks based IOCs
>> Hello everyone,
>> I suppose this is more a vxWorks question than an epics question, but here
>> is the issue.
>> I've got a VME based IOC running here at STAR that is having memory
>> problems.  Basically we noticed this issue as every 24-48 hours the IOC
>> would lose communication and all GUIs associated with it would go blank.
>> The solution is to re-start the IOC by rebooting the VME, but doing this
>> every day is not a good solution.
>> The epics is running on vxWorks, so I can use the memShow command to show
>> the memory usage at a given time.  I can see that as I open more and more
>> GUIs, the memory fills up.  At least part of the cause of the loss of
>> communication has to do with too many people opening GUIs relating to this
>> IOC at the same time.  However, I am not certain that this is the only
>> problem.
>> What I would like is to track the memory usage over time to see if there
>> is a time component as well as just too many GUIs being opened.  Does anyone
>> know how to do this in vxWorks?  Get it to print its memory usage every
>> minute or so to a log file or something similar?
>> Thanks
>> James
memory and vxWorks based IOCs James F Ross
Re: memory and vxWorks based IOCs Tim Mooney
Re: memory and vxWorks based IOCs James F Ross
Re: memory and vxWorks based IOCs Paul Sichta
Prev: Re: memory and vxWorks based IOCs Paul Sichta
Next: Re: BOY number representation & display scaling Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: memory and vxWorks based IOCs Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
