1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn and snmp
To: James F Ross <[email protected]>
Date: Thu, 21 Feb 2013 12:12:17 -0600
James,
Ah, you've tried to change too many things in the db file.  That text is actually formatting the snmpset/snmpget call and the expected text format/response.
In the case of the value you are looking at:
> WIENER-CRATE-MIB::outputVoltage.u0 = Opaque: Float: 4.500000 V
field(OUT, "@$(IP) guru WIENER-CRATE-MIB::outputVoltage.$(ch) 100 F")
Internally the driver is issuing a call much like the command line:
snmpset  -v 2c -m +WIENER-CRATE-MIB -c guru 192.168.1.100 outputVoltage.u0 F ###
The documentation from John Priller's site is excellent.
Paul
On Feb 21, 2013, at 10:41 AM, James F Ross <[email protected]> wrote:
> Hello everyone,
> As I mentioned in a previous email I'm trying to write an IOC that
> controls a wiener PL508 crate via snmp.  I have one that controls a
> PL512 crate and I'm trying to understand it so I can write an IOC for
> the PL508.
> At the moment, I'm focusing on how the .db files get the information
> from snmp.  The following record is a good example:
> record(ai, "HFT:PXL:U$(Ch):GetDemandVoltage")
>    field(DTYP,"asynFloat64")
>    field(INP,"@asyn($(IP) $(Ch) .1) Demand_Voltage")
>    field(SCAN,"5 second")
>    field(LINR,"LINEAR")
> Where Ch can be 0 through 11 and IP is the IP address of the crate.
> I believe that the key is this field:
> This should correspond to one of the following variables (obtained via
> snmpwalk).  I think the first is most likely the variable that the
> field gets its input from.
> WIENER-CRATE-MIB::outputMeasurementSenseVoltage.u0 = Opaque: Float: 0.000000 V
> WIENER-CRATE-MIB::outputMeasurementTerminalVoltage.u0 = Opaque: Float:
> 0.000000 V
> Does anyone know where a good guide to using asyn with snmp would be?
> Or perhaps a general epics/snmp guide?  I just need to know how
> "@asyn($(IP) $(Ch) .1) Demand_Voltage" points to outputVoltage.u0 and
> what I should put in other INP fields for other crate variables.
> Thanks!
> James
Re: asyn and snmp James F Ross
Prev: Re: asyn and snmp James F Ross
Next: Re: asyn and snmp James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
