Subject: |
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 25 Feb 2013 10:30:28 -0600 |
Hi Dirk,
On 2013-02-25 Dirk Zimoch wrote:
> I had to comment out cap5 for several cross linux architectures. (which
> I build as "HOST" architecture in order to have caget and friends.)
In 3.14.12.3 the catools products are built on all OSs except for vxWorks,
RTEMS and iOS (because those OSs don't support stand-alone executables). You
fixed the wrong thing, and you're probably compiling more stuff than you need
to on those cross-build architectures.
> Also
> if the compiler you use to build EPICS is not the one that was used to
> build perl you get into trouble.
That's the main problem on Windows, which is why cap5 can't usually be built
there — mixing the Perl and EPICS build systems is fragile. In 3.14.12.3
Windows doesn't try to run podchecker any more either.
> Do we really need cap5 in EPICS base? I would like to see it in a
> separate module.
Yes, I want to be able to use it in self-tests, so we can write regression
tests for record types and soft device support.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
- Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Dirk Zimoch
Compiling MEDM and Striptool on Ubuntu 1204 Kohler
Re: Compiling MEDM and Striptool on Ubuntu 1204 Andrew Johnson
<2013>
<2013>
