1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling MEDM and Striptool on Ubuntu 1204
To: [email protected]
Date: Mon, 25 Feb 2013 10:39:28 -0600
Hi Ivan,
On 2013-02-25 Kohler wrote:
> Just in case anyone is having problems compiling MEDM on Ubuntu1204,
> here are some tips:
> MEDM compile expects some library files in /usr/lib
Not actually true, you can adjust where the build looks for those files by
editing your extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86 file and
changing the X11_* and MOTIF_* settings.  The default values do assume that's
where they are found, but you should *never* need to modify your OS like that
to get EPICS programs to build or run.
> Remember to install the following package for the larger fonts used by
> MEDM to work on Ubuntu1204:
>    apt-get install xfonts-100dpi
That is true.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Compiling MEDM and Striptool on Ubuntu 1204 Kohler
Prev: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Next: Re: Compiling MEDM and Striptool on Ubuntu 1204 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Compiling MEDM and Striptool on Ubuntu 1204 Kohler
