1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling MEDM and Striptool on Ubuntu 1204
To: Kohler <[email protected]>
Date: Mon, 25 Feb 2013 10:43:46 -0600
On 2/25/13 10:18 AM, Kohler wrote:
> Hi,
> Just in case anyone is having problems compiling MEDM on Ubuntu1204,
> here are some tips:
> MEDM compile expects some library files in /usr/lib
> Ubuntu1204 puts these files in /usr/lib/i386-linux-gnu
> so one needs the following symbolic links in /usr/lib, MEDM then compiles:
>   ln -s /usr/lib/i386-linux-gnu/libXm.a /usr/lib/libXm.a
>   ln -s /usr/lib/i386-linux-gnu/libXt.a /usr/lib/libXt.a
>   ln -s /usr/lib/i386-linux-gnu/libXp.a /usr/lib/libXp.a
>   ln -s /usr/lib/i386-linux-gnu/libXmu.a /usr/lib/libXmu.a
>   ln -s /usr/lib/i386-linux-gnu/libX11.a /usr/lib/libX11.a
>   ln -s /usr/lib/i386-linux-gnu/libXext.a /usr/lib/libXext.a
>   ln -s /usr/lib/i386-linux-gnu/libXm.so /usr/lib/libXm.so
> Remember to install the following package for the larger fonts used by
> MEDM to work on Ubuntu1204:
>   apt-get install xfonts-100dpi
> For StripTool you also need:
>   ln -s /usr/lib/i386-linux-gnu/libXpm.a /usr/lib/libXpm.a
Hi, Ivan.
Creating those symlinks is *not* the right thing to do.  You're having
problems because Ubuntu 12.04 uses a "multiarch" [1] file system layout.
What you need to do is correctly define the X11_LIB, X11_INC, XPM_LIB,
etc. EPICS build system configure variables for your target
architecture.  (Or the EPICS build system would need to be made smarter.)
Lewis
1. http://wiki.debian.org/Multiarch
Compiling MEDM and Striptool on Ubuntu 1204 Kohler
Prev: Re: Compiling MEDM and Striptool on Ubuntu 1204 Andrew Johnson
Next: Re: Compiling MEDM and Striptool on Ubuntu 1204 Keith Thorne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
