1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: What I learned today...
To: <[email protected]>
Date: Thu, 28 Feb 2013 12:11:51 +0100
In our control system we have many scripts that generate multiple targets in
one go. With sequential make this is now problem, but when using parallel make
(make -j) we observed strange errors: target files were sometimes corrupt, or
missing, or just empty.
This message explains the issue with a simple example and show hoe to fix the
build rules so that these errors don't happen.
Suppose you have a script, say 'create_some_files.pl', that creates files
named 'one, 'two, 'three'. Your Makefile says:
TARGETS=one two three
all: $(TARGETS)
$(TARGETS): create_some_files.pl /usr/share/dict/words
one two three: create_some_files.pl
	./create_some_files.pl
Now, with parallel make, this may not work reliably, because the parallel make
will try to execute the script three times in parallel:
> make -j
Of course, your script may be written in such a way that executing it mroe
than once in parallel does no harm. But this is typically not the case, as
this requires extra effort. Furthermore, calling the script multiple times is
redundant (one run already creates all the files) and thus inefficient, even
if the script is re-entrant.
The generic solution is to split the make rule with an intermediate target:
$(TARGETS): files_created
files_created: create_some_files.pl
	touch files_created
This means the multiple targets depend on one single file (named
"files_created", here), so make knows that it has to create this file first
(before the targets). The rule for the targets is empty, so nothing is
executed. This indeed executes the script only once:
> make -j
touch files_created
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: What I learned today... Michael Davidsaver
Prev: Installing MEDM on UBUNTU 12.04 Yasemin Barbar
Next: seq: benign(?) error message when building with R3.15 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing MEDM on UBUNTU 12.04 Andrew Johnson
Next: Re: What I learned today... Michael Davidsaver
