Hi Ivan,
On 2013-03-04 Kohler wrote:
> If this helps I install the following packages to compile MEDM on Ubuntu
> 1204 and Ubuntu 1210.
Thanks for this:
> apt-get install autoconf libtool build-essential libmotif-dev
> apt-get install x11proto-print-dev libboost-program-options-dev
> apt-get install libxp-dev libreadline-gplv2-dev libxmu-dev
> apt-get install libxpm-dev # for StripTool
> apt-get install re2c # for sequencer in synApps
> apt-get install xfonts-100dpi # for all the larger MEDM fonts
We don't use autoconf, libtool, or Boost in EPICS, what are those packages
needed for? What does build-essential pull in?
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Re: Installing MEDM on UBUNTU 12.04 Kohler
RE: C++ logging framework for epics matthew.pearson
getBounds Zenon Szalata
<2013>
What I learned today... Benjamin Franksen
<2013>
