1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing MEDM on UBUNTU 12.04
To: tech-talk <[email protected]>
Date: Mon, 04 Mar 2013 10:36:15 +0200
If this helps I install the following packages to compile MEDM on Ubuntu 1204 and Ubuntu 1210.
apt-get install autoconf libtool build-essential libmotif-dev
apt-get install x11proto-print-dev libboost-program-options-dev
apt-get install libxp-dev libreadline-gplv2-dev libxmu-dev
apt-get install libxpm-dev        # for StripTool
apt-get install re2c              # for sequencer in synApps
apt-get install xfonts-100dpi     # for all the larger MEDM fonts
libxft2 libxft2-dbg are not needed.
Cheers,
Ivan
Re: Installing MEDM on UBUNTU 12.04 Andrew Johnson
Prev: RE: CA beacon question Hu, Yong
Next: Maven central and deprecating sourceforge maven repo Carcassi, Gabriele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing MEDM on UBUNTU 12.04 D Peter Siddons
Next: Re: Installing MEDM on UBUNTU 12.04 Andrew Johnson
