1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: What I learned today...
To: [email protected]
Date: Fri, 1 Mar 2013 14:03:34 -0600
Hi Ben,
On 2013-03-01 Benjamin Franksen wrote:
> Am Freitag, 1. März 2013, 17:50:41 schrieben Sie:
> > The main
> > reason is that we have a dependency in place so that no cross-builds can
> > start until after the host build has completed.  Those files will usually
> > be built and installed as part of the host build, so make will see them
> > as already up to date when it later checks them for each of the
> > cross-build targets.
> Thanks, I was not aware of this. Since when is this the case (i.e. only in
> 3.15 or is it in 3.14.12, too)?
This was added in 3.14.11 (see the Release Notes).
> And: will this same dependency (CROSS builds depend on HOST build to be
> complete) not also ensure that all architecture independent targets are
> already up-to-date when the CROSS build starts, so generating them directly
> inside $(COMMON_DIR) is not done multiple times in parallel? (Assuming, of
> course, that the rules are written to avoid accidental parallelism due to
> multiple targets in a non-pattern rule, as I explained in a previous
> message).
That's how we designed it work.  However some people put conditionals into
their Makefiles which might disable the DBD file generation on the host for
example.  Private rules that don't have correct dependency settings can also
result in the actions being run on all targets, and if the user never tries
parallel builds they might not notice this.
Problems with parallel builds can show up sooner or more often on Windows
because there the file-system won't let one process delete a file that another
process has open.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
What I learned today... Benjamin Franksen
Re: What I learned today... Andrew Johnson
Re: What I learned today... Benjamin Franksen
Prev: Re: What I learned today... Benjamin Franksen
Next: RE: CA beacon question Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: What I learned today... Benjamin Franksen
