1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: epics-perl & perlapi-5.10.1
To: [email protected]
Date: Mon, 11 Mar 2013 10:14:53 -0600
Hi Michael & Martin,
On 2013-03-11 Michael Davidsaver wrote:
> The added dependency is caused by a change I made to where libCap5.so is
> installed for the 3.14.12 series.  Previously if was installed in
> /usr/lib/epics/lib, now it is under /usr/share/perl5 (I'll check, but I
> think it should actually be in /usr/lib/perl5).
You almost certainly won't be able to use a libCap5.so that was built against
Perl 5.10 on Perl 5.14.  I introduced the Perl version number and architecture
into the path to libCap5.so to allow different Perl versions and architectures
to coexist in the same install directory.
> So avoiding the perlapi-* dep for epics-dev means moving (or removing)
> these scripts.  My current plan is to move CA.pm, libCap5.so, and the
> scripts which use them to a separate binary package.  Thoughts?
Sounds like a good idea.  The Perl5 major version number matters for this
package, and it sounds like you might have to have more than one version of
that package available for install depending on which Perl5 version is in use
on the system — I would hope that dpkg can do something like that.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: epics-perl & perlapi-5.10.1 Martin Konrad
Re: epics-perl & perlapi-5.10.1 Michael Davidsaver
Prev: Re: EDM Text Control Widget Motif behavior Isadoro Carlino
Next: Save and Restore parameters Julio Calvo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: epics-perl & perlapi-5.10.1 Michael Davidsaver
Next: Re: epics-perl & perlapi-5.10.1 Martin Konrad
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
