Hi folks, I would like to know if somebody here has any clue or maybe has developed something similar to this (I think it should be quite common): I need to
save and restore some parameters in a LLRF system based on EPICS. I am using AsynPortDriver and CSS. Once an interlock happens (a bi change to true, for example) I need the system to figure it out and save all the PV's values to a file, then I need to restore them. The solution should be different from the archiving system, I am not able to develop archiving in my system. Thank you so much for your help. Cheers. Julio.
ANJ, 20 Apr 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
