1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS UTC Time conversion
To: "[email protected] Talk" <[email protected]>
Date: Tue, 16 Apr 2013 14:51:33 -0700
This is intended to run on linux and OS X, but I'll change the %T to %H:%M:%S just to be safe.
However, that's not the issue here.   Anyone out there familiar with the EPICS time conversion code that can explain what I'm doing wrong and how to fix it?
On Apr 16, 2013, at 2:38 PM, Mark Rivers <[email protected]> wrote:
>> BTW %T is not portable; IIRC vxWorks and Windows do not support it, so don't
>> use it in anything that might run there.
> Not only is %T not portable to Windows, it causes an assert error, crashing the application.  There is no clue as to what went wrong unless you run it in the debugger.
> Mark
EPICS UTC Time conversion Eric Norum
Re: EPICS UTC Time conversion Andrew Johnson
RE: EPICS UTC Time conversion Mark Rivers
Prev: RE: EPICS UTC Time conversion Mark Rivers
Next: RE: EPICS UTC Time conversion Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
