Hi Eric,
Perhaps force the isdst flag to 0 in between calls:
> epicsTimeToGMTM(&tm, &nsec, ×tamp);
tm.tm_isdst = 0;
> epicsTimeFromTM(&utc, &tm, 0);
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Eric Norum
> Sent: Tuesday, April 16, 2013 1:18 PM
> To: [email protected] Talk
> Subject: EPICS UTC Time conversion
> I'm trying to convert an EPICS time stamp into a string -- but in UTC, not the local time
> zone.
> Here's my failing attempt:
> epicsTimeStamp timestamp;
> epicsTimeStamp utc;
> struct tm (tm);
> unsigned long nsec;
> char cbuf[80];
> epicsTimeToStrftime(cbuf, sizeof cbuf, "%F_%T", &utc);
> The resultant string is one hour off. It's as if the routines above are trying to apply
> daylight savings time correction to UTC.
> For example, consider the following POSIX time stamp:
> date -u -r 1366124582
> Tue Apr 16 15:03:02 UTC 2013
> If, in the above code, I set
> timestamp.secPastEpoch = 1366124582 - POSIX_TIME_AT_EPICS_EPOCH;
> timestamp.nsec = 0;
> The resultant string is: 2013-04-16_16:03:02
> See how the hours are '16' instead of '15'.
> So, what's the trick to getting a true UTC time string from an EPICS time stamp?
> Eric Norum
> [email protected]
- Re: EPICS UTC Time conversion Eric Norum
- EPICS UTC Time conversion Eric Norum
<2013>
2025
<2013>
2025
