1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS UTC Time conversion
To: Eric Norum <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 16 Apr 2013 16:23:03 -0700
Not too fast:
epicsTimeToGMTM
converts timestamp to UTC broken-down time. tm_isdst is already zero since UTC has no DST.
Next:
epicsTimeFromTM()
converts a broken-down time back to a timestamp. It needs timezone information
to know how to do the conversion (uses 'mktime' internally). The conversion depends
on the timezone and DST where the broken-down time is interpreted.
Note that epicsTimeToStrftime again converts the timestamp to broken-down
format internally; this time using 'localtime' - which also uses timezone information.
You want the epicsTimeFromTM() and epicsTimeToStrftime from- and (implicit) to-TM
conversions to cancel so that you display your UTC.
What went wrong?  epicsTimeToGMTM() returns a tm with 'tm_dst==0'.
This is what you feed to epicsTimeFromTM(). However, the implicit localtime()
operation uses the DST setting of the current timezone, which right now
is probably 1.
In order to make this work you should set it to a negative value
epicsTimeToGMTM(&tm, &nsec, &timestamp);
tm.tm_isdst = -1; /* determine value from current timezone and timestamp */
epicsTimeFromTM(&utc, &tm, 0);
/* Note that the 'utc' timestamp is not truly representing the time 'tm' in UTC
   but 'tm' interpreted as the local time. It is only the subsequent, implicit
   conversion of the timestamp back to a 'tm' (again in the local timezone)
   which renders a representation of UTC again in the guts of
   epicsTimeToStrftime() -- ugly */
I recommend testing with various settings of the "TZ" environment variable
to make sure you got it right.
Lesson learned:
  epicsTimeFromTM() and epicsTimeToStrftime() both convert using
  the local timezone.
HTH
- Till
On 04/16/2013 03:02 PM, Eric Norum wrote:
Good idea, but doesn't seem to help:
    timestamp.secPastEpoch = 1366124582 - POSIX_TIME_AT_EPICS_EPOCH;
    timestamp.nsec = 0;
    tm.tm_isdst = 0;
    epicsTimeToStrftime(cbuf, sizeof cbuf, "%F_%H:%M:%S", &utc);
    printf("%s\n", cbuf);
produces
    2013-04-16_16:03:02
But
date -u -r 1366124582
Tue Apr 16 15:03:02 UTC 2013
On Apr 16, 2013, at 2:54 PM, "Allison, Stephanie" <[email protected]> wrote:
Hi Eric,
Perhaps force the isdst flag to 0 in between calls:
tm.tm_isdst = 0;
EPICS UTC Time conversion Eric Norum
RE: EPICS UTC Time conversion Allison, Stephanie
Re: EPICS UTC Time conversion Eric Norum
Prev: Re: EPICS UTC Time conversion Andrew Johnson
Next: Re: EPICS UTC Time conversion Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS UTC Time conversion Eric Norum
Next: Check Box widget in CSS BOY Hovanes Egiyan
