1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: autosave limitation?
To: Emmanuel Mayssat <[email protected]>
Cc: emmanuel mayssat <[email protected]>, [email protected]
Date: Tue, 16 Apr 2013 23:38:00 -0500 (CDT)
----- Original Message -----
> From: "Emmanuel Mayssat" <[email protected]>
> To: "Kay Kasemir" <[email protected]>
> Cc: "emmanuel mayssat" <[email protected]>, [email protected]
> Sent: Tuesday, April 16, 2013 5:03:12 PM
> Subject: RE: autosave limitation?
> > Depending on what version of autosave you are using, you can work
> > without any standalone autosave config files.
> > Instead, you add annotations to your database records:
> > record(type, "$(S):SomeRecord")
> > info(autosaveFields, "VAL LOW")
> > In your IOC startup file you then add a command that auto-creates
> > the request files from those database annotations:
> > makeAutosaveFileFromDbInfo("autocreated.req", "autosaveFields");
> > create_monitor_set("autocreated.req.req", 5)
> Again, I want the flexibility to have 1 master IOC with 20 devices to
> be broken in several
> (i.e. let's say I reconfigure the master IOC with 15 devices and 5
> single-device IOCs that actively being developed)
> This should of course be transparent from the EPICS client
> perspective
> (i.e. restored values are the same)
> I understand how to generate the req file (dbgrep * > file.req or
> more complicated as described above)
> But what about restoring the PVs, i.e. what about the sav files?
> There are 2 solutions:
> 1/ Have one req file per device --> one sav file per device
> 2/ Have one req file per device --> one sav file used for all IOCs
> But
> 1/ Limits on number of sav files in autosave
> 2/ I anticipate issues as several processes try to write to the same
> file
> is there a reason why autosave is limited to 8 files?
> Can this limit be raise to say ... 1000?
> Better yet, can this limit be removed?
> I moved away from autosave some time ago due to that limit.
> Is there anything that has the same functionality as autosave but
> would better fit my development methodology?
> Regards,
> Emmanuel
There's no real reason autosave is limited to 8 files, other than that I
didn't know anyone wanted more than that.  I haven't tested large numbers
of files, but you can edit save_restore.h and change
#define MAXRESTOREFILES 8
to whatever you want.  The number of save files is already unlimited (you
can make as many create_monitor_set() calls as you want.)
Yes, the number of restore files could be made unlimited.  That's what I
meant to imply when I said that the list of restore file names could be
implemented as a linked list.  If someone wants 1000 files, then a linked
list is probably called for.  If 30 is enough, then
#define MAXRESTOREFILES 30
seems adequate.  All we're doing is allocating an array of pointers.
Tim
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
RE: autosave limitation? Emmanuel Mayssat
Prev: Re: EPICS UTC Time conversion Eric Norum
Next: RE: sscan/ saveData problem with RW permission, and not an NFS issue Vesna Samardzic-Boban
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: autosave limitation? Emmanuel Mayssat
Next: RE: autosave limitation? Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
