I don't think it can work in that kernel - the ftdi_sio module only allows
a single vendor:product pair to be passed as a parameter and udev will
only see events for devices that are recognised by the ftdi_sio module.
Guy Jennings
On Apr 18, 2013, at 4:00 PM, "J. Lewis Muir" <[email protected]> wrote:
> On 4/18/13 3:15 PM, Mark Rivers wrote:
>>> With no /dev/ttyUSB* device files, what happens if the second device is
>>> plugged in first?
>> Without unplugging the devices I can unload the driver
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -r -v ftdi_sio
>> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko
>> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
>> At this point there are no /dev/ttyUSB devices:
>> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB*
>> ls: No match.
>> Now I load the driver for model 3006
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3006 debug
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3006 debug
>> It works, and ttyUSB0 exists:
>> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB0
>> crw-rw---- 1 root dialout 188, 0 Apr 18 15:09 /dev/ttyUSB0
>> Now I unload the driver again:
>> No /dev/ttyUSB devices:
>> ls: No match.
>> Now I load the driver but for model 3000 this time:
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3000 debug
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3000 debug
>> So it works. But I don't know how to also have it recognize the second device. As Andrew said, loading the driver again does nothing:
>> I'll look into udev.
> Hi, Mark.
> I still think your modprobe command should work.
> Do you still have your 81-Agilis.rules udev rules file loaded containing:
> SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3000", MODE="0666"
> What happens if you add another rule for model 3006?
> SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3006", MODE="0666"
> What happens if you connect both devices, but after connecting the
> second, wait 60 seconds in case the /dev/ttyUSB1 file is somehow slow to
> show up?
> Lewis
- Re: Linux USB serial questions J. Lewis Muir
- Linux USB serial questions Mark Rivers
- RE: Linux USB serial questions Mark Rivers
<2013>
<2013>
