1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling ca_context_create(1) too late
To: [email protected]
Date: Fri, 19 Apr 2013 10:45:52 -0500
Hi Michael,
On 2013-04-19 [email protected] wrote:
> I've just discovered that calling ca_context_create(1) after iocInit()
> appears to succeed (it returns ECA_NORMAL) ... but the resulting context
> is not very healthy!  In my particular case I find that
> ca_array_get_callback delivers zero length data, but I expect other deeper
> problems are to be found.
Is your code running in the main thread, or its own private thread?  If this
is a private thread then Mark's comment applies — you must ensure that the
thread does not call any other CA functions before ca_context_create() is run.
If this code is running in the IOC's main thread then that's a different
issue; I'm not sure what context the main IOC thread belongs to, if any, but
you probably can't assume that code running after iocInit is the first routine
to create a CA context for the main thread.
> I understand that I need to call ca_context_create() a good deal earlier,
> but I don't really understand why it appears to succeed -- is it possible
> for an error code to be returned instead, please?  (In some future version
> of EPICS, I'm testing this on 3.14.11.)
It does return a status, but it is not a failure to have multiple contexts
running in a process at the same time.  I'm guessing that the API can't
distinguish your case from a more advanced user, so it's quite happy to do
what you asked.
> Alternatively, is there some reliable way I can test whether it has
> succeeded?  I don't have full control over when my library is initialised,
> so detecting an error immediately would be more friendly to the user.
You can use ca_current_context() to find out if there is context set for the
current thread yet.  This returns a NULL pointer if no context has been
created yet.  If the result is not NULL you may be able to use the
undocumented (and mis-spelled) routine (with a prototype in cadef.h)
    int ca_preemtive_callback_is_enabled(void);
to find out whether that context is preemptive or not.
HTH,
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
RE: Calling ca_context_create(1) too late michael.abbott
Prev: RE: Calling ca_context_create(1) too late Mark Rivers
Next: Re: Add choice to dbd file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Calling ca_context_create(1) too late michael.abbott
Next: RE: Calling ca_context_create(1) too late michael.abbott
