1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Calling ca_context_create(1) too late
To: <[email protected]>, <[email protected]>
Date: Tue, 23 Apr 2013 08:18:20 +0000
I've finally isolated the issue when calling ca_context_create(1) late ... and it's something to do with how the zero count is handled in ca_array_get_callback -- to be precise, when calling
	ca_array_get_callback(dbrcode, 0, channel, callback, context)
the size of the returned array differs, depending on whether ca_context_create(1) was called before or after iocInit!  Note that this problem only occurs with internal PVs, for external PVs the correct count is returned in both cases.
I've attached a complete example IOC -- just compile it and run `test` or `test 1` in the root.  Running `test` will call ca_context_create(1) late and will print out 'count = 0'; running `test 1` calls ca_context_create(1) early and prints out 'count = 1'.  I've tested this with both 3.14.11 and 3.14.12.3.
I can't find documentation for the expected behaviour of calling ca_array_get_callback() with a zero count, but I've never encountered problems with this before: up to now I've expected to get the "natural" record size.  Note that if the PV being fetched is an external PV then 'count = 1' is printed as expected.
Note, by the way, that my earlier diagnosis (that something else was also calling ca_context_create() and conflicting) appears to have been completely wrong.  Sorry about the red herring.
Here's the core of the IOC:
test.c
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <cadef.h>
#include <iocsh.h>
static chid pv_channel;
static void on_get(struct event_handler_args args)
    printf("on get\n");
    printf("count = %ld\n", args.count);
static void on_ca_connect(struct connection_handler_args args)
    printf("on connect\n");
    ca_array_get_callback(3, 0, pv_channel, on_get, NULL);
int main(int argc, char **argv)
    bool early_create = argc > 1  &&  *argv[1] == '1';
    printf("Creating CA context %s\n", early_create ? "early" : "late");
    if (early_create)
        ca_context_create(1);
    iocsh("TEST.cmd");
    if (!early_create)
    ca_create_channel("TESTPV", on_ca_connect, NULL, 0, &pv_channel);
    sleep(1);
    return 0;
TEST.cmd
dbLoadDatabase("dbd/TEST.dbd", NULL, NULL)
TEST_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("TEST.db", NULL)
iocInit()
TEST.db
record(bo, "TESTPV")
Attachment: test-ioc.tgz
Description: test-ioc.tgz
Re: Calling ca_context_create(1) too late Andrew Johnson
Calling ca_context_create(1) too late michael.abbott
Prev: RE: caget delays tom.cobb
Next: FW: Calling ca_context_create(1) too late michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Calling ca_context_create(1) too late michael.abbott
Next: Re: Calling ca_context_create(1) too late Andrew Johnson
