1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: caget delays
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 23 Apr 2013 08:04:01 +0000
What does ifconfig say? Am I right in thinking the problematic machine is the one with many network interfaces?
Tom Cobb
+44 (0)1235 778582
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: 23 April 2013 00:13
> To: 'Andrew Johnson'
> Cc: EPICS Tech Talk
> The problematic IOC is on a dual-boot system, Linux Fedora Core 14 and
> Windows 7 64-bit.
> I just rebooted it with Windows.
> Initially caget and caput worked without delay.  But after running the
> IOC for a while it is now in a state where caget and caput are again
> slow.  This is from a remote Linux system to the Windows IOC.  The IOC
> computer is more than 90% idle.
> I have now modified the 3.14.12.3 version of caput to also print the
> time in various steps:
> corvette:base/src/catools>../../bin/linux-x86_64/caput
> 13PS1:cam1:Acquire 0
> Old : 13PS1:cam1:Acquire             Done
> New : 13PS1:cam1:Acquire             Done
>  Time to create context=0.000555
>     Time to connect PVs=0.030361
>         Time to put PVs=0.000936
>     Time for ca_pend_io=0.000006
>         Time to get PVs=0.000381
> Time to destroy context=2.010504
>              Total time=2.042742
> corvette:base/src/catools>../../bin/linux-x86_64/caget
> 13PS1:cam1:Acquire
>  Time to create context=0.000547
>     Time to connect PVs=0.030242
>         Time to get PVs=0.000579
> Time to destroy context=2.010867
>              Total time=2.042235
> This is running caget and caput from a remote Windows 7 machine:
> H:\epics\base\src\catools>..\..\bin\windows-x64\caput
>  Time to create context=0.007857
>     Time to connect PVs=0.040451
>         Time to put PVs=0.007289
>     Time for ca_pend_io=0.000005
>         Time to get PVs=0.007154
> Time to destroy context=8.858039
>              Total time=8.920796
> H:\epics\base\src\catools>..\..\bin\windows-x64\caget
> 13PS1:cam1:Acquire
>  Time to create context=0.011290
>     Time to connect PVs=0.033812
>         Time to get PVs=0.006111
> Time to destroy context=4.530879
>              Total time=4.582092
> So destroying the context is taking 2 to 9 seconds on these systems for
> both caput and caget.
> I also learned a little more about my problem with using IDL to start
> the cameras, with IDL doing a caput to the Acquire PV.  It always works
> fine to start the cameras the first time the script is running after
> starting IDL.  However, running the script again always causes the
> cameras to lose close to 100% of their frames.
> Thanks,
> Mark
> Sent: Monday, April 22, 2013 4:43 PM
> Cc: EPICS Tech Talk
> I did another test, running the new version of caget on the problematic
> Linux machine itself, the one whose IOC has long times to destroy the
> context.
> I find the if EPICS_CA_ADDR_LIST is localhost it is very fast, but if
> it is the broadcast address of my subnet it is slow.
> Colorado:areaDetector/iocBoot/iocPS3>setenv EPICS_CA_ADDR_LIST
> localhost
> Colorado:areaDetector/iocBoot/iocPS3>/corvette/usr/local/epics/base/bin
> /linux-x86-gcc43/caget 13PS1:cam1:Acquire
> Time to create context=0.000799
> Time to connect PVs=0.028771
> Time to get PVs=0.000303
> Time to destroy context=0.001288
> Total time=0.031160
> 164.54.160.255
> Time to create context=0.000783
> Time to connect PVs=0.028628
> Time to get PVs=0.000367
> Time to destroy context=1.999753
> Total time=2.029531
> From: [email protected] [[email protected]] on
> behalf of Mark Rivers [[email protected]]
> Sent: Monday, April 22, 2013 4:32 PM
> Cc: EPICS Tech Talk
> Hi Andrew,
> The problem is not that the IOC is busy running the cameras. The same
> long delay when running caget/caput/cainfo occurs even if the cameras
> are not acquiring. This is a quad-core Linux machine, and when the
> cameras are not acquireing all CPUs are less than 3% busy. The network
> is essentially idle with less than 15 KB/sec traffic.
> I modified the caget program from base-3.14.12.3 to print the time
> required for each operation.
> Here are the results when running caget to a similar Prosilica IOC on a
> busier but "non-problematic" Linux server:
> 13IDAPS1:cam1:Acquire
> 13IDAPS1:cam1:Acquire Done
> Time to create context=0.000516
> Time to connect PVs=0.028928
> Time to get PVs=0.000327
> Time to destroy context=0.000643
> Total time=0.030414
> So the total time is 30 ms, and the time to destroy the context is 643
> microseconds.
> This is the result to that same Linux IOC from a Windows 7 64-bit
> machine:
> Time to create context=0.008363
> Time to connect PVs=0.035649
> Time to get PVs=0.006076
> Time to destroy context=0.002816
> Total time=0.052904
> So the total time is 53 ms, and the time to destroy the context is 2.8
> ms.
> Now here are the results from the Linux and Windows machines to the
> "problematic" IOC, which is completely idle because the cameras are not
> acquiring:
> 13PS1:cam1:Acquire
> Time to create context=0.000591
> Time to connect PVs=0.029165
> Time to get PVs=0.000520
> Time to destroy context=3.602033
> Total time=3.632309
> 13PS1:cam1:Acquire
> Time to create context=0.020868
> Time to connect PVs=0.043227
> Time to get PVs=0.005942
> Time to destroy context=8.930734
> Total time=9.000772
> So from both Linux and Windows the time to create the context, connect
> to the PVs and get the PV values are essentially the same as on the
> non-problematic IOC.
> However, the time to destroy the context is 3.6 seconds on Linux and
> 8.93 seconds on Windows!!!
> What could possibly be causing this? How do I debug it?
> Thanks,
> Mark
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 22, 2013 10:11 AM
> To: Mark Rivers
> Subject: Re: caget delays
> Hi Mark,
> On 2013-04-22 you wrote:
> > However, when I run the caget program from EPICS base this is what I
> get:
> > corvette:prosilicaSupport/GigE_SDK_Linux_v1.26/documents>date ;
> > /corvette/usr/local/epics/base/bin/linux-x86-gcc43/caget
> > 13PS1:cam1:Acquire ; date Mon Apr 22 09:43:51 CDT 2013
> > Mon Apr 22 09:43:53 CDT 2013
> > So it takes 2 seconds. This only seems to happen to this particular
> IOC,
> > not to all IOCs. The IOC is running areaDetector for Prosilica
> cameras,
> > but the cameras are not running. It does not matter how many IOCs are
> > running on that Linux (Fedora core 14) host.
> As I said in my reply a few minutes ago, I think this is because
> caget/caput
> program is waiting for the CA connection to close down, and it's taking
> that
> IOC some time to respond to the "close" request from the client because
> it's
> busy running the cameras. Does it still take the 2 seconds if you stop
> the
> camera acquisition so the IOC is not busy? IDL is not closing down CA,
> so
> it's not waiting for the shutdown to finish.
> Running the IOC as a SCHED_FIFO process could also fix this, see the
> wiki page
> I pointed you to.
> - Andrew
> It is difficult to get a man to understand something, when his salary
> depends upon his not understanding it. -- Upton Sinclair
RE: caget delays Mark Rivers
Prev: RE: caget delays nick.rees
Next: RE: Calling ca_context_create(1) too late michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: caget delays Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
