1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: genesys power supply IOC
To: Jiro Fujita <[email protected]>
Date: Mon, 22 Apr 2013 12:05:27 -0400
The database file genesysPSAll.db had both 07G-ECD-BL08 and 17G-ECD-BL14 in it.  I changed both occurrences to GEN8-180-88Z.  The startup command file looks correct.
On Mon, Apr 22, 2013 at 11:57 AM, Jiro Fujita <[email protected]> wrote:
James,
The sample IOC that I got from Stephanie has the following in the st.cmd:
#!../../bin/linux-x86/genesys
cd ../..
dbLoadDatabase("dbd/genesys.dbd")
genesys_registerRecordDeviceDriver(pdbbase)
## Location of stream protocol files
epicsEnvSet "STREAM_PROTOCOL_PATH", "iocBoot/soft-iocps/"
dbLoadRecords("db/genesysPSAll.db")
#drvAsynIPPortConfigure("07G-ECD-BL08", "aaa.bbb.ccc.ddd:8003",0,0,0)
#drvAsynIPPortConfigure("17G-ECD-BL14", "aaa.bbb.ccc.eee:8003",0,0,0)
drvAsynIPPortConfigure("GEN8-180-88Z", "xxx.xxx.xxx.xxx:8003",0,0,0)
Obviously, line 13 and 14 are commented out.  I did that, as STAR HFT's PS was called as such.  In this copy, I blocked out the IP (as the rest of the world does not need to know that).
As you can see, "07G-ECD-BL08" is one of the sample one that I disabled (but it was originally there from SLAC version).  So, check your startup command (and other things for that matter).
On Apr 22, 2013, at 5:38 PM, James F Ross <[email protected]> wrote:
Yes, 07G-ECD-BL08 shows up in a lot of the database files.  I'll set about changing those and see if that helps.
Thanks all
James
On Mon, Apr 22, 2013 at 11:35 AM, Jiro Fujita <[email protected]> wrote:
James,
Port 8003 is correct on this one.  This is mostly based upon genesys IOC that I got from Stephanie Allison at SLAC.
The problem is most likely that your start up command is calling device called "GEN8-180-88Z" (which is what the Genesys that STAR HFT has), where as somehow, it is expecting "07G-ECD-BL08" (which I don't know where it come from).  You may want to double-check the db and dbd files.  I seem to remember something of that.
I will check a bit more in detail on what I have on the test machine at Creighton...
On Apr 22, 2013, at 5:20 PM, James F Ross <[email protected]> wrote:
I believe it uses TCP (it communicates via an ethernet connection).  Below is my start up script.  I got this IOC after it had been compiled on another machine, so it is quite possible I missed changing something.
cd ../..
drvAsynIPPortConfigure("GEN8-180-88Z", "130.199.60.184:8003",0,0,0)
iocInit()
# Start sequences
seq(&psControl,"ps=GEN8-180-88Z")
I know the IP is right for the drvAsynIPPortConfigure, but I don't know if 8003 is correct.
Thank you
James
On Mon, Apr 22, 2013 at 11:05 AM, Mark Rivers <[email protected]> wrote:
Can you explain the interface to the power supply?  It is serial, TCP, etc.
How have you configured the asyn port?
Can you send your startup script?
From: [email protected] [[email protected]] on behalf of James F Ross [[email protected]]
Sent: Monday, April 22, 2013 9:45 AM
To: EPICS Tech Talk
Subject: genesys power supply IOC
Hello all,
I'm trying to set up an IOC for a genesys power supply.  It compiles, but when I try to run st.cmd I get the following errors (showing up in red after iocInit):
2013/04/22 09:37:58.974089 _main_ Businterface '07G-ECD-BL08' not found for '07G-ECD-BL08:Curr'
2013/04/22 09:37:58.974603 _main_ 07G-ECD-BL08:Curr: Can't attach to bus 07G-ECD-BL08 -1
2013/04/22 09:37:58.974715 _main_ 07G-ECD-BL08:Curr: Record initialization failed
Segmentation fault
I'm using asyn version 4.21, StreamDevice version 2.6, epics 3.14.12.1, and sequencer 2.0.12.
From what I've been able to find, this seems to be a problem between StreamDevice and asyn.  I originally had aysn 4.13 before getting 4.21 and trying that.  Neither solved the issue though.  Anyone have any experience with this kind of issue?
Thanks!
James
Re: genesys power supply IOC James F Ross
RE: genesys power supply IOC Mark Rivers
Re: genesys power supply IOC Jiro Fujita
Prev: Re: genesys power supply IOC Jiro Fujita
Next: Re: genesys power supply IOC James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
