Thanks to help from Michael Davidsaver the problem with the delay in caget is solved. The problem was a DNS misconfiguration, so that reverse DNS lookup of the IOC IP address to IP name was not working. The 2 second delay was the time for the DNS lookup to timeout.
Sent: Tuesday, April 23, 2013 9:44 AM
To: [email protected]; [email protected]
Cc: [email protected]
Subject: RE: caget delays
> What does ifconfig say? Am I right in thinking the problematic machine is the one with many network interfaces?
No, this machine is not the one with many network interfaces. That machine is at SLAC. This is a machine in my lab at APS with only 1 physical Ethernet interface. ifconfig does show virbr0, which as I understand it is a virtual bridge. I don't recall installing anything to create that.
Colorado:areaDetector/iocBoot/iocPS2>/sbin/ifconfig
eth0 Link encap:Ethernet HWaddr 00:18:8B:06:4E:34
inet addr:164.54.160.135 Bcast:164.54.160.255 Mask:255.255.255.0
inet6 addr: fe80::218:8bff:fe06:4e34/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:71112 errors:0 dropped:0 overruns:0 frame:0
TX packets:30707 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:46510457 (44.3 MiB) TX bytes:3611768 (3.4 MiB)
Interrupt:16
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:4784 errors:0 dropped:0 overruns:0 frame:0
TX packets:4784 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:219472 (214.3 KiB) TX bytes:219472 (214.3 KiB)
virbr0 Link encap:Ethernet HWaddr 92:27:89:BF:6C:1F
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1925 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:123893 (120.9 KiB)
Doing a caget on a PV on this machine from a remote Linux machine yields:
corvette:~>/usr/local/epics/base-3.14.12.3/bin/linux-x86/caget 13PS1:cam1:Acquire
13PS1:cam1:Acquire Done
Time to create context=0.000570
Time to connect PVs=0.028991
Time to get PVs=0.000349
Time to destroy context=2.008363
Total time=2.038273
So it takes 2 seconds to destroy the context.
Running caget on the local machine with the IOC also takes 2 seconds if EPICS_CA_ADDR_LIST on both the IOC and caget points to the broadcast address of the Ethernet:
Colorado:areaDetector/iocBoot/iocPS2>setenv EPICS_CA_ADDR_LIST 164.54.160.255
Colorado:areaDetector/iocBoot/iocPS2>setenv EPICS_CA_AUTO_ADDR_LIST NO
Colorado:areaDetector/iocBoot/iocPS2>/corvette/usr/local/epics/base-3.14.12.3/bin/linux-x86-gcc43/caget 13PS1:cam1:Acquire
Time to create context=0.000765
Time to connect PVs=0.028665
Time to get PVs=0.000367
Time to destroy context=2.005270
Total time=2.035068
However, if I run both the IOC and caget with EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=localhost then caget runs with no delay
Time to create context=0.000763
Time to connect PVs=0.029004
Time to get PVs=0.000310
Time to destroy context=0.001978
Total time=0.032054
Sent: Tuesday, April 23, 2013 3:04 AM
To: Mark Rivers; [email protected]
Tom Cobb
+44 (0)1235 778582
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: 23 April 2013 00:13
> To: 'Andrew Johnson'
> Cc: EPICS Tech Talk
> The problematic IOC is on a dual-boot system, Linux Fedora Core 14 and
> Windows 7 64-bit.
> I just rebooted it with Windows.
> Initially caget and caput worked without delay. But after running the
> IOC for a while it is now in a state where caget and caput are again
> slow. This is from a remote Linux system to the Windows IOC. The IOC
> computer is more than 90% idle.
> I have now modified the 3.14.12.3 version of caput to also print the
> time in various steps:
> corvette:base/src/catools>../../bin/linux-x86_64/caput
> 13PS1:cam1:Acquire 0
> Old : 13PS1:cam1:Acquire Done
> New : 13PS1:cam1:Acquire Done
> Time to create context=0.000555
> Time to connect PVs=0.030361
> Time to put PVs=0.000936
> Time for ca_pend_io=0.000006
> Time to get PVs=0.000381
> Time to destroy context=2.010504
> Total time=2.042742
> corvette:base/src/catools>../../bin/linux-x86_64/caget
> 13PS1:cam1:Acquire
> Time to create context=0.000547
> Time to connect PVs=0.030242
> Time to get PVs=0.000579
> Time to destroy context=2.010867
> Total time=2.042235
> This is running caget and caput from a remote Windows 7 machine:
> H:\epics\base\src\catools>..\..\bin\windows-x64\caput
> Time to create context=0.007857
> Time to connect PVs=0.040451
> Time to put PVs=0.007289
> Time for ca_pend_io=0.000005
> Time to get PVs=0.007154
> Time to destroy context=8.858039
> Total time=8.920796
> H:\epics\base\src\catools>..\..\bin\windows-x64\caget
> 13PS1:cam1:Acquire
> Time to create context=0.011290
> Time to connect PVs=0.033812
> Time to get PVs=0.006111
> Time to destroy context=4.530879
> Total time=4.582092
> So destroying the context is taking 2 to 9 seconds on these systems for
> both caput and caget.
> I also learned a little more about my problem with using IDL to start
> the cameras, with IDL doing a caput to the Acquire PV. It always works
> fine to start the cameras the first time the script is running after
> starting IDL. However, running the script again always causes the
> cameras to lose close to 100% of their frames.
> Thanks,
> Mark
> Sent: Monday, April 22, 2013 4:43 PM
> Cc: EPICS Tech Talk
> I did another test, running the new version of caget on the problematic
> Linux machine itself, the one whose IOC has long times to destroy the
> context.
> I find the if EPICS_CA_ADDR_LIST is localhost it is very fast, but if
> it is the broadcast address of my subnet it is slow.
> Colorado:areaDetector/iocBoot/iocPS3>setenv EPICS_CA_ADDR_LIST
> localhost
> Colorado:areaDetector/iocBoot/iocPS3>/corvette/usr/local/epics/base/bin
> Time to create context=0.000799
> Time to connect PVs=0.028771
> Time to get PVs=0.000303
> Time to destroy context=0.001288
> Total time=0.031160
> 164.54.160.255
> Time to create context=0.000783
> Time to connect PVs=0.028628
> Time to destroy context=1.999753
> Total time=2.029531
> From: [email protected] [[email protected]] on
> behalf of Mark Rivers [[email protected]]
> Sent: Monday, April 22, 2013 4:32 PM
> Cc: EPICS Tech Talk
> Hi Andrew,
> The problem is not that the IOC is busy running the cameras. The same
> long delay when running caget/caput/cainfo occurs even if the cameras
> are not acquiring. This is a quad-core Linux machine, and when the
> cameras are not acquireing all CPUs are less than 3% busy. The network
> is essentially idle with less than 15 KB/sec traffic.
> I modified the caget program from base-3.14.12.3 to print the time
> required for each operation.
> Here are the results when running caget to a similar Prosilica IOC on a
> busier but "non-problematic" Linux server:
> 13IDAPS1:cam1:Acquire
> 13IDAPS1:cam1:Acquire Done
> Time to create context=0.000516
> Time to connect PVs=0.028928
> Time to get PVs=0.000327
> Time to destroy context=0.000643
> Total time=0.030414
> So the total time is 30 ms, and the time to destroy the context is 643
> microseconds.
> This is the result to that same Linux IOC from a Windows 7 64-bit
> machine:
> Time to create context=0.008363
> Time to connect PVs=0.035649
> Time to get PVs=0.006076
> Time to destroy context=0.002816
> Total time=0.052904
> So the total time is 53 ms, and the time to destroy the context is 2.8
> ms.
> Now here are the results from the Linux and Windows machines to the
> "problematic" IOC, which is completely idle because the cameras are not
> acquiring:
> 13PS1:cam1:Acquire
> Time to create context=0.000591
> Time to connect PVs=0.029165
> Time to get PVs=0.000520
> Time to destroy context=3.602033
> Total time=3.632309
> 13PS1:cam1:Acquire
> Time to create context=0.020868
> Time to connect PVs=0.043227
> Time to get PVs=0.005942
> Time to destroy context=8.930734
> Total time=9.000772
> So from both Linux and Windows the time to create the context, connect
> to the PVs and get the PV values are essentially the same as on the
> non-problematic IOC.
> However, the time to destroy the context is 3.6 seconds on Linux and
> 8.93 seconds on Windows!!!
> What could possibly be causing this? How do I debug it?
> Thanks,
> Mark
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 22, 2013 10:11 AM
> To: Mark Rivers
> Subject: Re: caget delays
> Hi Mark,
> On 2013-04-22 you wrote:
> > However, when I run the caget program from EPICS base this is what I
> get:
> > corvette:prosilicaSupport/GigE_SDK_Linux_v1.26/documents>date ;
> > /corvette/usr/local/epics/base/bin/linux-x86-gcc43/caget
> > 13PS1:cam1:Acquire ; date Mon Apr 22 09:43:51 CDT 2013
> > Mon Apr 22 09:43:53 CDT 2013
> > So it takes 2 seconds. This only seems to happen to this particular
> IOC,
> > not to all IOCs. The IOC is running areaDetector for Prosilica
> cameras,
> > but the cameras are not running. It does not matter how many IOCs are
> > running on that Linux (Fedora core 14) host.
> As I said in my reply a few minutes ago, I think this is because
> caget/caput
> program is waiting for the CA connection to close down, and it's taking
> that
> IOC some time to respond to the "close" request from the client because
> it's
> busy running the cameras. Does it still take the 2 seconds if you stop
> the
> camera acquisition so the IOC is not busy? IDL is not closing down CA,
> so
> it's not waiting for the shutdown to finish.
> Running the IOC as a SCHED_FIFO process could also fix this, see the
> wiki page
> I pointed you to.
> - Andrew
> It is difficult to get a man to understand something, when his salary
> depends upon his not understanding it. -- Upton Sinclair
- RE: caget delays Mark Rivers
- RE: caget delays tom.cobb
Re: Sequencer Benjamin Franksen
Fwd: vishnu chaudhari
<2013>
How to create EPICS device support for a simple serial or GPIB device Vahe Sahakyan
<2013>
