Hi All,
Does anyone have a need to resolve regular expressions in the dbpr command?
I often issue a dbgrep immediately followed by a dbpr and thought it would be useful if I could do both together. Example:
sioc-sys0-ml00>dbgrep("SIOC:SYS0:ML00:FWF0*")
SIOC:SYS0:ML00:FWF01
SIOC:SYS0:ML00:FWF02
sioc-sys0-ml00>dbpr("SIOC:SYS0:ML00:FWF01")
ASG: BUSY: 0 DESC: spare DISA: 0
DISP: 0 DISV: 1 NAME: SIOC:SYS0:ML00:FWF01
NORD: 1 SEVR: NO_ALARM STAT: NO_ALARM TPRO: 0
VAL: (nil)
sioc-sys0-ml00>dbpr("SIOC:SYS0:ML00:FWF02",)
DISP: 0 DISV: 1 NAME: SIOC:SYS0:ML00:FWF02
VAL: (nil)
...could be replaced with:
sioc-sys0-ml00>dbpr("SIOC:SYS0:ML00:FWF0*")
VAL: (nil)
VAL: (nil)
In addition to the interest level argument, I'd like to add an option to display them in one column. Example:
sioc-sys0-ml00>dbpr("SIOC:SYS0:ML00:FWF0*",0,1)
ASG:
BUSY: 0
DESC: spare
DISA: 0
DISP: 0
DISV: 1
NORD: 1
SEVR: NO_ALARM
STAT: NO_ALARM
TPRO: 0
VAL: (nil)
ASG:
BUSY: 0
DESC: spare
DISA: 0
DISP: 0
DISV: 1
NORD: 1
SEVR: NO_ALARM
STAT: NO_ALARM
TPRO: 0
VAL: (nil)
Motivation: Currently the SLAC electron beam line controls group uses an IRMIS crawler to get PV information into the RDB by crawling every IOCs st.cmd. Our engineers add new, but valid, syntax that results in us having to massage that crawler quite a bit. I would like to add a command to all of our IOC startup scripts that generates a list of PVs and fields that can easily crawled and inserted into the IRMIS RDB. Example:
iocshCmd("dbpr(*,5,1) >/data/iocInfo/IOC.pvEveryField")
Opinions?
Could this be a code-a-thon topic?
Mike
- Re: Would like to add regular expressions to dbpr Andrew Johnson
Re: EPICS Extensions Compilation Errors Janet Anderson
Re: EPICS Extensions Compilation Errors Pete Jemian
<2013>
Re: EPICS Extensions Compilation Errors Dirk Zimoch
<2013>
