1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM
To: [email protected]
Date: Fri, 10 May 2013 11:31:47 -0500
Hi Zenon,
On 2013-05-10 Zenon Szalata wrote:
> zms@esaanal2 $ caput ESA:LO:SC:2531-21:CH1:MAXV-WR:DATA 100
> Old : ESA:LO:SC:2531-21:CH1:MAXV-WR:DATA 50
> New : ESA:LO:SC:2531-21:CH1:MAXV-WR:DATA 100
> and the Text Control immediately showed the new value.  From now on it
> will work just fine until the IOC is restarted.
> I suspect that part of the problem is how I am initializing these Text
> Control widgets.  At this point I am still struggling with the fact that
> after the IOC is started, the PV in question has the correct value which
> comes from a register in the hardware and is represented incorrectly in
> the EDM Text Control widget.
Is something writing this value directly to the record's VAL field after
iocInit but without processing the record?  Since the DTYP said "Soft Channel"
it didn't occur to me that something else might be modifying the fields
directly, which would explain the issue (it shouldn't be doing that).
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Re: EDM Zenon Szalata
EDM Zenon Szalata
RE: EDM Mark Rivers
Prev: Re: EDM Zenon Szalata
Next: Asyn-based TCP/VXI-11 interface to many devices Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EDM Zenon Szalata
