1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Asyn-based TCP/VXI-11 interface to many devices
To: epics Techtalk <[email protected]>
Date: Fri, 10 May 2013 09:43:23 -0700
Hi all.
We are planning for installation of new beamlines requiring approximately 130 magnet power supplies. The proposed supplies (a few different manufacturers and models being considered) may be controlled using VXI-11/Telnet style interfaces, and using SCPI style commands. This implies the use of StreamDevice + Asyn interfaces in EPICS IOCs. My concern is about the scalability of ssyn with the large number of TCP connections to the power supplies. Each power supply will require an asyn IP port to be maintained. Until now, I have only configured asyn-based applications using 2 or 3 ports on a single IOC. This seems like a significant departure from what I consider a conventional system.
The IOC platform would probably be a VME hosted CPU running Linux, with an ethernet interface dedicated as a kind of VXI-11 fieldbus. It is possible, or likely, that control of the 130 supplies will be spread across 2 or 3 hardware IOC hosts.
Does anyone have any experience with this kind of configuration? Any problems to anticipate? Any problems that have known solutions? I am planning to try some kind of simulation using multiple physical hosts, possibly using multiple virtual hosts on each. Each host/virtual-host would simulate a power supply. Does this seem like a representative test?
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: Asyn-based TCP/VXI-11 interface to many devices Eric Norum
Prev: Re: EDM Andrew Johnson
Next: Re: Asyn-based TCP/VXI-11 interface to many devices Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: about the interface MCA problem that Matlab can't read real-time image from areaDetector zengzr
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
