1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM
Date: Fri, 10 May 2013 12:14:29 -0700
Hi Andrew,
On 05/10/13 11:08, Andrew Johnson wrote:
Hi Zenon,
On 2013-05-10 Zenon Szalata wrote:
The hardware registers are read/write.
When the IOC starts, the register has some value previously set.
After IOC init, I issue a series of dbpf commands, one for each register.
These trigger processing a record that reads the register.
After the register is read, the read value is put into the output record
with NPP.
The record you showed was Soft Channel though, was this what you're calling an
an output record?  I see that it does have a forward link.
Yes, it is a longout record, so I called it output.
These are Beckhoff bus terminal records which are a bit complicated to
read from and especially to write to.  To have it work correctly, I need
to insert a 0.2 second delay between dbpf commands.
I decided to use NPP because the output record, although it is soft
channel, when processed will result in the value being written back to
the register, which should be harmless, but I wanted to avoid it,
because significantly more delay would be needed.
Unfortunately for most record types doing a dbPut() to the VAL field without
processing the record will *not* trigger a CA monitor for the field.  If the
VAL field is PP(TRUE) the code in dbPut() assumes that puts to the field will
cause the record to be processed and that processing will trigger a monitor,
so it doesn't do one itself to avoid sending an unnecessary double update.  In
your case though you're not processing the record, so EDM never gets sent an
update even though subsequent caget or dbpr commands do show the new value.
I started this thread after observing that EDM was singling out one particular record and always the same one. Number of similar records were handled the same way and their values made it to the Text Controls. Also, relaunching the EDM was not enough to get the correct value. Just this morning I discovered that restarting the EDM program would get the correct value. I was strongly convinced and no longer am that closing a screen (one of many control by an EDM program) resulted in CA disconnect to all PVs referenced by that screen. I thought that just putting the screen in question in a debug mode and then back in execute, would also do CA disconnect/connect or at least the correct values would be obtained. This was not happening. Well, I am still confused by this whole thing.
If this is really the cause of my difficulty, I will think how to modify
the records such that the target output record gets the value and gets
processed and somehow writing back to the register will be suppressed.
I was trying to avoid the extra complication.
The SDIS link of the subsequent record might be useful here.
- Andrew
Thanks Andrew,
Zen
EDM Zenon Szalata
Re: EDM Andrew Johnson
Re: EDM Zenon Szalata
Prev: Re: channel archiver questions James F Ross
Next: new archiver problem James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM Andrew Johnson
Next: epicsTimeGetEvent failed Geon-Yeong Mun
